Disconnected battery, now one rear window won't auto roll down/up
2slowvw
Moderator
VA
2022 Tesla Model 3
Sure they do. I tried it on my car first just to make sure.
ATR
Baltimore
'17 Golf R 6mt
Small update for everyone.
Ran a vcds scan to see if there were any fault codes...
Sure enough, I have one in the passenger door module. It lost its configuration somehow.
I'll try to get more details on the fault tomorrow morning. Thought my laptop was fully charged... NOPE :eek:
ATR
Baltimore
'17 Golf R 6mt
Okay folks as promised here's the error I have in vcds... Odd that it shows up as the front passenger window when the rear passenger window is the issue...
Edit...stupid png image size restriction is preventing me from uploading it. Give me a minute
ATR
Baltimore
'17 Golf R 6mt
Here's the fault...
I'm going to try something BRB...
ATR
Baltimore
'17 Golf R 6mt
Here's the fault...
Alrighty, going through the basic settings I tried running through the adaptations for the rear window.
It failed.
All the other three windows worked fine.
As I said before I'll keep you all updated.
VOA West
West
I had the same issue with same vcds error,
This worked for me: when relearning the windows, instead of holding the window switch down/up for 3-5 seconds try double clicking the switch after its reached the top and bottom.
The Fed
Old Guys Rule
Florida
I think you need to do it only on the up cycle and not the down. It's been that way since the MK4. Where did anyone read the other way?
rcnacura
SF
If you have VCD or obd11, you'll want to do the basic window regulator test. Basically it just needs to relearn the up/down positions then will work normally.
Sent from my SM-N910V using Tapatalk
ATR
Baltimore
'17 Golf R 6mt
Already done (see post #20).
As I stated, it failed on the window that I'm having trouble with. Worked fine with the other three windows.
ATR
Baltimore
'17 Golf R 6mt
Car is at the dealership now. They'll be checking this out for me shortly.
I'll let everyone know what happens.
ATR
Baltimore
'17 Golf R 6mt
To follow up on this the dealership was able to go through the basic adaptations of the controller module and fix the problem.
