Don't believe the hype.
Adjusting corner weights on a daily driver is a waste of money and time.
I understand some won't like that, so let me explain why. Well, I'm say-
ing that as someone who already had this done several times and has
friends who had it done. But I also know when it makes sense and when
it does not.
It does make lots of sense when you have a race car. It does also do
make some sense when you track frequently
and have Clubsport coils
fitted with spring rates 2 or 3 times higher than standard (say, some-
where at 400 or 500 lbs). It does make sense when there's one specific
state for which you want to optimize your car for (one driver alone, no
cargo of course, 3/4 of fuel etc.).
Does anyone think that's the case on a daily driver? Obviously not.
I'm about to upgrade to height adjustable coilovers and am faced with the decision to corner balance or not. The alternative to corner balancing would involve carefully measuring ride height and trying to adjust to within 1/8".
Just to avoid some common misconception,
never try to even out unequal
wheel gaps by adjusting your coilovers. Of course you could adjust front +
rear even (or to some degree to your liking), but
never adjust left + right
differently without having scales on hand. Typically left and right must be
adjusted equally based on the threads. Ignoring this would mean that your
corner weights get
completely off,
much more compared to stock/standard.
You may have read that already:
http://www.golfmk7.com/forums/showthread.php?p=340025#post340025
It was a bit expensive for what it's worth, but it's nice to know that my car is setup to perfection.
Let me correct that for you, "setup to some imagination of perfection".
(honestly)
Keep in mind that a perfectly corner balanced car will not be at the same height at all four corners because of the weight of the driver and other asymmetries in the car.
Selfevidently, corner weight adjustment only makes sense with
the driver (or equivalent weight) on its seat. Likewise, it must
be clear, that corner weights are off with passengers in the car,
with cargo or perhaps even with a different fuel fill (not on 4WD
R with its symmetrical saddle style tank).
