COBB Tuning
GolfMK6 Official Vendor
- Austin, TX
I have a couple Cobb logs I'll have to check out and see if there are any values in the KR. I mean based on description I would think ignition is the overall timing for that cylinder (I've seen a similar value in VCDS I believe), knock retard is the same as IGN 2-5 on the JB4 (actual degrees being pulled) and ignition timing final is after knock has been subtracted.. this is ignition 1 on the JB1.
Really I think their descriptions make more sense if this is the case. Knock should be knock and ignition is the timing on the cylinder and final seems to make sense to me lol. Now I need someone to log with KR, ignition and final to see if this is correct lol. Ideally someone with knock lol
Ah, okay, so the JB4 has one that only shows timing being pulled. Must be what Cobb is using, just using a name that makes more sense. I've never logged with either the JB1 or VCDS.
With ATR, a lot of people never got that everything you're looking at (same for AT-Pro) is something Cobb made up. Not in a bad way, but they're doing the software from scratch, just reverse engineering the code however that works, then translating it into english for us. They can label stuff whatever they want. Me like "KR."
I believe you're correct regarding the monitor break-down. For future reference, you can utilize our Monitor List to confirm what you're looking at. The per-cyl Ignition Timing/Knock Retard monitors are listed below.
Ignition Timing Cylinder 1 Current cylinder 1 ignition timing.
Ignition Timing Cylinder 2 Current cylinder 2 ignition timing.
Ignition Timing Cylinder 3 Current cylinder 3 ignition timing.
Ignition Timing Cylinder 4 Current cylinder 4 ignition timing.
**Knock Retard Cyl. 1 Knock Retard for cylinder 1
**Knock Retard Cyl. 2 Knock Retard for cylinder 2
**Knock Retard Cyl. 3 Knock Retard for cylinder 3
**Knock Retard Cyl. 4 Knock Retard for cylinder 4
I believe the tunes keep them active, but severely handicap them. Let us know if that fixes it
Correct, sorta. We can turn the light off however the checks will still run in the background. If checks do fail the code will still be present if a scanner is connected.
Marshall@COBB
