Both camera and harness need to be changed, different wiring and camera has more wires.Hi,
For reroofing Camera from Low to High with OEM stuff does it require to change camera or it just require to change harness? Does anyone knows?
I saw there is also Mid cameras existing? How to know which you have ? Low or MID? and i saw this which is quite cheaper then change whole set.Both camera and harness need to be changed, different wiring and camera has more wires.
Not sure if there is a Mid camera, from what i know there are 2 cameras, simple one and the other with moving guidelines and different view modes.I saw there is also Mid cameras existing? How to know which you have ? Low or MID? and i saw this which is quite cheaper then change whole set.
https://www.carsystems.eu/vw-golf-7...lowline-camera-to-highline-camera,id3918.html
Tomorrow i ll post but pretty sure that is low. But look at link that i posted, upgrade kit? So it doesnt need to reddo all cables in whole car i guess, but does it count as oem retrofit?Not sure if there is a Mid camera, from what i know there are 2 cameras, simple one and the other with moving guidelines and different view modes.
Can you take picture of your camera? I can tell you if it's high or low.
Lowline camera should only have 5 wires, Highline Should have 7.
I think you will need to redo wiring, there are 2 gateway wires that need to go all the way to the camera from the back of the MIB unit, and reverse signal is not needed anymore as the car gets it from gateway.Tomorrow i ll post but pretty sure that is low. But look at link that i posted, upgrade kit? So it doesnt need to reddo all cables in whole car i guess, but does it count as oem retrofit?
