JackJoachim
- Biloxi, MS
Just placed my order and got the data cable as well. Can't wait until it come in!
When i get the unit, do i need to change the map to map 1 before installing? Or is it already selected when shipped out from you?
Follow-up from a couple of weeks ago. Can't seem to recreate this problem, so perhaps it was just an engine hiccup. JB1 is working great - thanks George!I've updated my earlier posts, but I've encountered somewhat similar behavior before (i.e. prior to JB1 installation). I'll see if I can capture a video at some point, but it happens so seldom that it's hard to capture.
Hi,
The offer will be for all new JB1's purchased regardless if the JB4 is released. That way if you want you can try the JB1 and see if its enough for you then go JB4 without loosing out.
Yes, the bluetooth replaces the need for a data cable. It can do all that the desktop version can do including the map settings etc.
So, what's the latest on how long is the JB4 expected to be? I'm dying to do something and like the removability but am not sure the JB1 is enough for what I want.
What if I bought the JB1 used from another forum member?
We still working on details.
Just have to add wiring which will connect to obd portI'll still be able to upgrade though, right? Just won't be a discount? Does the upgrade just involve adding wiring to the JB1, or do you have to replace the unit? Thanks. Just got one for a great deal and very excited to get it, it I know I will want to go further down the road.
I should have mine installed within the next couple of days. All of the gas we have here is E10, but I can get 93 octane no problem. I also have a station about 20 minutes away from me that sells E85. What would the benefit of mixing in a couple of gallons of E85 with the 93 octane E10? Can make like an E25 or E30. What's the max out cars can handle? Also, any benefit to changing the spark plugs? My only other mods are a modified stock airbox with a drop in filter. I cut out the vents in the grill that are right in front of the intake and blocked off the other side where it feeds from stock. Essentially a sealed cold air.
