Lights I bought.
Posi-taps for power.
Tesa tape.
They arrived, rear door warning lights should go in this weekend.
Testing the connection, turns out the bulbs can be put in backwards. Connecting both lights in a chain to the passenger was suggested by Bold-sport, however I've seen installs where each side is run to the corresponding front footwell. In this instance since the kit came pre-wired I had no desire to mess with it.
Here you can sorta see where I tapped into the front passenger footwell for power. Tesa tape wrapped around the harness to protect and assist with tucking under body panels. I went along the passenger door sill. About 2" of wire is visible where it goes under the seat rail as I was reluctant to pull up the sill to run the wires under carpet.
Here is where the light housings go. I did have to cut a little foam out to make room.
Running the wire up under the passenger seat rail, under the center console and along the backside. Wire was tucked under after this pic.
It works! Their function follow the same principles as other interior lights. Since the lights are connected to passenger front footwell light they can be dimmed along with the rest of the interior accent lighting.
Tesa tape.
