toledospeed
- 3rd rock
Correct rev1 upgrade. For data cable VW with grey shell for Rev1.
If you are in SA, you are up pretty late! Or up really early, haha!
When connecting to the jb4 using Bluetooth via the iPhone app, what engine / kit rev do you select?
George any plans E85/flex-fuel like you do for the BMW?
Yes, in the long run we will add it. We working on a virtual flex fuel sensor with similar logic to what the manufacturers use. This is being tested now on the BMW side and once we have success we will scale it over to VW and start using the data for the Autotune map we working on.
High volumes at this point will require the LPFP to be replaced as a minimum. There is a controller coming out soon which will allow for a larger Walbro to be fitted. Once this is out we will start doing work on secondaries relative to the market demand.
Hey George, is JB4 update for code clearing released yet?
