BMS JB4 R specific thread
robstahl
Culver City, CA
any performance benefit over a JB1 staying stock?
I have a 2016 golf r with JB1 with only a resonator delete. I dont plan on modifying it anymore. Is there any need to get a JB4 upgrade?
Thanks
Rob
George Smooth
South Africa
Thanks
Rob
If you happy with the power delivery of the car and smoothness no real need to upgrade. If you want it to drive more refined with a slight power gain then its well worth it.
britet
CT
I am strongly considering getting either the JB1 or JB4, but a lot of the technical aspects go over my head. I just want my car to go faster. Can you advise "for dummies":
1. What advantages do the JB4 offer over the JB1, considering I will likely just "set it and forget it" and have no real interest in keeping track of the technical data?
2. Which map would likely be best for me, where I just want as much increased power/torque as possible without having to worry about switching maps or comparing data? For fuel would be using 93 octane R+M/2 method (USA).
Thanks!!!!
Mk72015
N/A
Thanks!!!!
I would get the Jb4 for sure, not the Jb1. Jb4 you always half the datalog capability and adjustable settings. I think if your bone stock you will be running map 1, George is a great guy and he will be able to answer any questions you do have.
George Smooth
South Africa
Thanks!!!!
Hi,
Both units have set and forget maps so best bet is to check which install suites you better. Also relative to if your car is a manual or DSG I can recommend maps etc.
Thanks,
gEorge
RAubry
Toronto
Hi George, I just installed the Bluetooth unit, so far the difference is incredible, I have a 034 Motorsport intake, charge pipes and turbo muffler delete. No downpipe yet. I want to try map 6 with your recommendations. How many logs should I send you and at which map setting?
I did not tap into the AFR wire to keep as OEM as possible, would this be a must if I want map 6?
Thanks
rr1santos
san diego
looking at tunes to stack with jb4...would it be advantagous at all? looking at eurodyne..
Yamdan1
Sweden
What cable to connect?
Is it the upper or lower to connect the blue wire to?
George Smooth
South Africa
Thanks
Yes over map 1 I would advise the AFR tap.
