Guys thinking of putting spacers. 10 mm rear and 3 mm front.
What brand is the best in terms of quality and reliability?
Sent from my SM-G935F using Tapatalk
this^^...none???
I realized my mistake ??? still grateful to all responders. Yes H&R seem to be dominant here. I'm thinking twice b4 using them as I saw lots of negative reviews. Eibach is not available in stock but can easily get it.Tamer, you should mention you're not living in the US.
As a consequence, ECS isn't your 'natural choice' but something sold
worldwide instead, like H&R or Eibach, which is what I'd go for (if I'd
do spacers, which I never will).
this^^
ECS not an option here in Dubai. May I ask what is meant by hubcentric? H&R and Eibach r hubcentric?My ECS flush kit is perfect. Make sure whatever spacers you get are hubcentric so the wheels center on them.
Stock R wheels 8x19 ET50 + 5 mm spacers make resulting ET45 which is commonly
perceived as 'ideal' along with 235s.
Best spacers in ur opinion are ....
A bit of a band aid.
I prefer to order a wheel with the proper offset and use no spacer. Spacers are OK if the correct units are sourced. I used a spacer on my Spec Miata with no problems but will say spacers create more leverage on your bearings and bolts. Hubcentric spacers are worlds better than just a spacer sitting there. Remember it's the hub that should be used to locate your wheel, not your bolts.
