APR Presents the MK7 GTI Catback Exhaust System
Arin@APR
GOLFMK7 Official Sponsor
Auburn, Al
B8 S4, MK7 GSW TDI
Product Page
The APR Catback Exhaust System personalizes your vehicle’s looks, sound and performance. Beautifully hand-crafted T304-stainless-steel components adorn the system with stunning TIG-welding throughout. Our straight-through satin-finished mufflers are configurable to your desire, smoothing the exhaust note to a deep growl, without adding restrictions, rasp or drone. Strong high-quality bracketry and OEM-style clamps hold the system steadily in place, making the install or removal a snap, and fitment simple, yet precise. A cast 3” to dual 2.5” rear splitter creates an ultra-smooth transition, steadily feeding exhaust gasses out of the system, while looking tidy from under the rear bumper. Finally, removable 4" satin-finished slash-cut exhaust tips finish the system, adding a classy motorsport-inspired touch to the rear of the vehicle.
Quick Facts
  • T304 stainless-steel construction
  • Argon-back-purged TIG welding throughout
  • Single 3" to dual 2.5" mandrel-bent brushed tubing
  • Ultra-smooth cast 3" to dual 2.5" splitter
  • Satin-finished mufflers with optional easy-change center unit for sound customization
  • Satin-finished 4" slash-cut exhaust tips (removable)
  • Rugged and precise mounting brackets
  • OEM style slip clamps and Torca AccuSeal T304 tip clamps
  • Direct fit to the OEM and APR downpipe exhaust systems with the included link and reducer pipes
  • Low-profile design, suitable for lowered vehicles
  • Larger diameter piping compared to stock
  • Larger diameter tips compared to stock
  • Lighter weight, in all configurations, compared to stock
  • Designed, developed, assembled and quality controlled in-house
  • Easy to install
  • Limited lifetime warranty
System Overview
Our exhaust system uses larger piping compared to the factory exhaust system, yet weights 5 lbs. less and 1 lb. less with the optional front muffler. We use 3" OD piping, which then splits to a dual 2.5" design. The factory system uses 2.56" piping, which reduces to 2.36" before splitting, greatly diminishing the overall diameter of the system. Finally, our system’s 4" exhaust tips dwarf the factory 3.15" tips, giving the rear of the vehicle a sportier look.
Mufflers
The mufflers are responsible for tuning the exhaust note and do so without adding unnecessary restrictions to the system. Each unit features a straight-through perforated tube that’s tightly wrapped with stainless steel and fiberglass material. The mufflers have a beautiful satin finish, and are tucked high in the exhaust tunnel, making them perfect for lowered vehicles.
The system comes standard with a single muffler with the option of adding our front triangular muffler at any time. The system sounds deep, throaty, and devoid of rasp and drone in all configurations. The single muffler setup will be perfect for most customers, especially those with the factory downpipe. When upgrading the downpipe, or going to a larger turbocharger, the system gets louder. For those who want it quieter, our drop-in front muffler makes for an excellent upgrade.
Axle-Back Components
We cast the axle-back splitter to maximize the system’s performance by keeping exhaust velocity high and back pressure low. This is accomplished by gradually splitting the system from a single 3” pipe to dual 2.5” pipes. The organically shaped casting allows us to make this transition gradually as to not disturb the flow of gasses. Furthermore, as this component is visible from the rear of the vehicle, we made sure form matched function with a beautiful surface finish, TIG welding, unique bracketry and brushed, mandrel bent tubing.
Brackets
Our brackets ensure a strong and precise fit, every time. With our design, you’ll never need to worry about the brackets sagging and losing their shape over time, or the post slipping out of the hangers. The brackets are rigid, exact in their position, fit snugly in place and are made to stand the test of time.
Tubing
We use T304 stainless steel tubing throughout. We brush and de-burr all pipes, use mandrel bending techniques to ensure the pipes keep a constant diameter throughout, and use argon-back purged TIG welding for a strong and attractive weld.
Tips
Our satin-finished slash-cut 4” exhaust tips upgrade the rear of the vehicle dramatically. The motorsport-inspired tips tuck nicely into the factory valance, gently following the valance’s curves and demanding all the right attention in all the right places. We laser etch a small and discreet APR logo onto the top of each tip, and we use T304 stainless Torca AccuSeal clamps that bolt on with ease with hardware that rotates out of sight. Lastly, since the tips are removable, you can upgrade to any one of our upcoming optional tip designs at any time.
Clamps
Our system uses OEM-style low-profile slip clamps and T304 stainless-steel Torca AccuSeal clamps for the exhaust tips. Our clamp selection allows the system to sit high in the exhaust tunnel, as is favored by lowered vehicles, with ultimate compatibility no matter what downpipe you may have. The clamps make for easy swapping of the exhaust tips, and slide out of the way to make adding or removing the optional front muffler easy. Each connection point is strategically placed to ensure the system has minimal opportunity to rotate during install or during years of heavy driving. Finally, because there are no flanges or swedges on the pipe, fitting the system to the factory downpipe, APR downpipe, or other downpipes is a breeze. There’s no cutting, welding, or glaring compatibility issues, and there are no gaskets to replace.
Hanger
We’ve added an extra bracket and associated rubber hanger to our main muffler to make use of an unused factory mounting point. This ensures the system installs snugly in place, without an opportunity to move, or rotate, under prolonged use.
Downpipe Compatibility
We’ve designed our system to be 100% bolt-on with the factory exhaust downpipe and APR downpipe. There’s no cutting, welding, or finagling to get the system to fit. It simply bolts on thanks to the included reducer for use with the factory downpipe, and link pipe for use with the APR downpipe.
Created In-House
Our exhaust systems are proudly designed, developed, assembled and quality controlled in-house at the APR 78,000 sq.ft performance campus in Opelika, Alabama.
Sound Tests
APR Catback with OEM Downpipe
APR Catback with Optional Front Muffler and OEM Downpipe
APR Catback with and APR Downpipe
APR Catback with Optional Front Muffler and APR Downpipe
Purchasing Information
Volkswagen MK7 GTI / Clubsport (Front Wheel Drive)
CBK0001 - Photo - $999.99 - APR Catback Exhaust System
CBK0005 - Photo - $224.99 - APR Front Muffler
Locate an APR Dealer to Purchase
Pricing applicable to the USA only. Please contact an APR Importer for pricing in other countries. Information subject to change. Please visit our product page for the most current information.
kDizz781
Boston
yes!
scrapin240
IzzaGolf
Golf
Looks well made and no bogus HP/TQ claims. So basically all for sound, which is totally OK in this game, albeit a bit pricey.
A little concerning though and is sometimes hard to tell on videos, but it sounds like it drones even with the optional muffler and APR DP.
rjtrout
Denver, CO
Lifetime warranty, so you're good to go.
Here's my opinion:
OEM DP - APR CB - APR Front Muffler = Quiet
OEM DP - APR CB - No Front Muffler = Mild
APR DP - APR CB - APR Front Muffler = Just right
APR DP - APR CB - No Front Muffler = Loud!
I think it sounds dead on! I will be contacting my local dealer shortly....
Arin@APR
Auburn, Al
B8 S4, MK7 GSW TDI
My colleagues and I had trouble really capturing the sound. The tone is deep, not raspy or tiny, but it doesn't drone. I've heard MK7 system that drone and this is nothing like them.
scrapin240
IzzaGolf
Golf
Can't wait to hear it then. Hope someone nearby in NYC gets one so I can hear it. It would go well with my other APR products and tunes on the car already.
Sent from my LG-H870DS using Tapatalk
ExcelerateRep1
Branford, CT
I don't know but I get all excited anytime I see something cast... always drawn to that split y pipe every time I see it. I like the triangular tunnel resonator too.
Fit and Finish = A+
Have a bunch of these on order :)
