Codes: P0413 secondary air injection system switching valve A circuit open
P0045 turbo charger boost control solenoid circuit/open
P00AF00 Turbo boost control A module performance static
17 Alltrack with HPA is38+ (unitronic ecu/tcu). is38 was professionally installed 5 months ago.
I've done a little research to see what might cause these but hoping someone has dealt with this exact combo.
Wagen drove fine on the way to work, no boost after.
After pulling codes and wiggling things around a bit there were no more codes and had full boost.
BUT, I have a feeling the issue will come back.
I assume one of these codes caused other issues then throwing the codes.
Where should I start?
