I picked up a set of RAZO pedals. They perfectly raised the gas pedal, while lowering the brake pedal (I took off the rubber pedal cover for it, before installing the RAZO one), and they significantly improved the spacing between the pedals.
Do you have any pictures of yours? I basically drilled and screwed the aftermarket pedal on top of the metal base, which raised it a little bit... but it's not leveled with the brakes. It's better than the stock one, but there's still a significant difference in height.
I wish VW stuck with the floor-mounted pedal design
