I currently have a 2015 A3 with a Vortex xl turbo running E30. After getting a custom tune from EQT the car ran well for a couple weeks but after that the car started misfiring. The first issue was one of the hoses inside the gas tank that connected to the LPFP fell off. Also one of the hoses inside the gas tank connecting too the LPFP was little bent but I managed to straighten it out. While doing the custom tune some oil got passed the PCV causing white smoke to come out. The car has 3.5inch CTS downpipe, CTS cold air intake, CTS inlet pipe, 1300cc CTS mpi kit, EQT charge pipe/ Turbo Muffler Delete, APR intercooler, Upgraded 5 bar TMAP/PUT sensors, Stage 3 DSG tune, NGK racing R7438-9, APR Coil Packs. I have tried replacing my APR coil packs with the OEM ones, no difference still Misfiring under WOT. Spark Plugs have just been changed no difference. AFR was at 9.55 when doing one of the pulls. I will leave the picture of my cobb with 9.55 AFR same with a VCDS scan and 2 logs I did that day with the car misfiring. Also the vcds scan was done at the start of my problems but currently the misfire doesn't trigger any codes. Thank you for the help.
10 Faults Found:
15074 - Cylinder Disabling
P130A 00 [00100000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:45
Engine RPM: 6863.00 /min
Normed load value: 56.9 %
Vehicle speed: 147 km/h
Coolant temperature: 91 C
Intake air temperature: 23 C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.218 V
Unlearning counter according OBD: 10
Engine: operating status: PL
N_TOOTH: 6915 /min
T_AST_SAE: 1684 s
Engine oil temperature: 102.0 C
STATE_LS_SAE[1]: OL_ERR
FUP_H_SAE: 20920.0 kPa
FUP_EFP_MES: 7816.8 hPa
Cylinder 3
P0303 00 [01100000] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:44
Engine RPM: 6723.50 /min
Normed load value: 61.2 %
Vehicle speed: 144 km/h
Unlearning counter according OBD: 28
N_TOOTH: 6765 /min
T_AST_SAE: 1683 s
Engine oil temperature: 101.0 C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 20720.0 kPa
FUP_EFP_MES: 3860.64 hPa
15134 - Cylinder 4
P0304 00 [01100000] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:44
N_TOOTH: 6765 /min
T_AST_SAE: 1683 s
STATE_LS_SAE[1]: CL
15128 - Cylinder 2
P0302 00 [01100000] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:44
N_TOOTH: 6765 /min
T_AST_SAE: 1683 s
STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [01100000] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:44
N_TOOTH: 6765 /min
T_AST_SAE: 1683 s
STATE_LS_SAE[1]: CL
10 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:45
N_TOOTH: 6915 /min
T_AST_SAE: 1684 s
Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:44
N_TOOTH: 6765 /min
T_AST_SAE: 1683 s
STATE_LS_SAE[1]: CL
15134 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:44
N_TOOTH: 6765 /min
T_AST_SAE: 1683 s
STATE_LS_SAE[1]: CL
15128 - Cylinder 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:44
N_TOOTH: 6765 /min
T_AST_SAE: 1683 s
STATE_LS_SAE[1]: CL
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 148487 km
Date: 2023.10.16
Time: 13:31:44
N_TOOTH: 6765 /min
T_AST_SAE: 1683 s
STATE_LS_SAE[1]: CL
