Can anyone confirm if these calipers will bolt up to the mk7.5 Golf R..
reason i'm asking is I have a set in my garage, and would like to use them
I found the solution.. you can shave down the spindle of the mk7.5 or go the route i did and order mk6 spindle and bearings, from there it should be direct bolts on..
you have to either machine down your current spindle or switch spindles completely...
Parts you will need if switching spindles:
mk6 spindles
mk6 wheel bearings
mk6 ABS sensors
