15mm rear spacers. Can i go 20???
Tamer
UAE
GTIans; I installed eibach prokit and 10mm front / 15mm back spacers. The wheels are just about flush. I am thinking of going a bit wider on the rear. 20 instead of 15mm. Any reasons why to do or not to do?
Let me know what u think.
Sent from my SM-G935F using Tapatalk
nype
Vancouver, B.C.
Looks flush enough to me.
But would help to know the wheel specs.
nype
Vancouver, B.C.
http://willtheyfit.com
You're already 13.7mm more poke on all 4 corners than a stock GTI with the Austin wheels (18x7.5 ET49).
Considering that the "flush kit" spacers are 15mm front and 20mm rear, you're pretty much at that point on the front already, without any spacers. Personally, I wouldn't go more poke than the levels of these flush kit spacers. In other words, with your setup, I'd leave the front and add 5mm spacers to the rear.
I can't comment on ill effects of going wider, rubbing etc. You'd have to detail the tire specs, if you've lowered the car etc
But I can tell you that you're certainly going fo fling more road debris up the sides and the back of your car, the wider you go.
Tamer
UAE
Thanks a lot for ur reply. I went 4 mm extra just today. Will post a photo soon. So far no impact. I'm het to experience the debris flinging you mentioned. Makes sense that it would happen.
nype
Vancouver, B.C.
Maybe a non-issue since you're in UAE. I'm in Raincouver.
Tamer
UAE
after pics
couple of after pics.
