Is yours manual? I remember in my 2015 1.8t when I let the clutch go when the engine was cold, after I had selected a gear, the turbo would make a blow off valve noise like what a modified Supra would make. Not one word of an exaggeration. I thought there was a problem but talked to other owners and they said that the turbo is boosting many PSI when the engine is cold, to warm it up quicker and warm the cat up quicker, so when the turbo is boosting, you interrupt it by selecting a gear and depressing the clutch, the engine stops the turbo from boosting so much, and it loses pressure, and makes that noise. Maybe this isn't the noise you're talking about.
