pixlgeek
- Houston, TX
I'm trying to retrofit blind spot monitoring. I have all the parts but the full wiring harness wants me to tap into two lines on the BCM harness. Instead of tapping the factory harness, I figured I'd make a Y splitter using repair wire and maybe even a 2 prong connector that would work with the pins/terminals.
Does anyone have an idea of what terminal types these are and which repair wires would work. As an added bonus if you could point me in the direction of a 2 pin plug that would work, it would be super.
