I was at the track today and had some brake issues that cut my day short. This was probably for the better as on the way home I started hearing some clunking. At first I thought it was the noise that was coming from brakes, but it gradually got worse and eventually the car started pulling to the left. I pulled to side of freeway and see four of my lug bolts on the ground and the wheel slanted. Turned out the lug bolts somehow jostled free (I torqued the wheel last night and during tech inspection this morning to 88 ft-lbs). There was also a lot of metal flaking on the wheel.
I managed to get the lug bolts back in, got off the highway, and slowly made my way home stopping every few miles to re-torque the bolts since they kept coming loose. Now I have my car apart and noticed that the front wheel bolt seats are no longer circular. I also noticed that the hub lug bolt holes do not quite line up with the brake rotor and looks like the lugs dug into the rotor metal when being screwed in. The lugs themselves also have messed up threads (probably did damage the hub at this point?). The lugs have some surface rust on the ends - would this have caused them to get over-torqued even though I was torquing to 88 ft-lbs? And the hubs are quite rusty too... yay midwest.
So the question is - do I need a new wheel, a new hub, both? This isn't even getting into my iSweep IS2500 brake pads disintegrating after 2 sessions. I came to the track with 7mm on the drivers side and 8mm on the passenger. The drivers side inside is now bare metal in some areas and all four front pads are less then 2mm. Rotors are pretty toast too due to metal on metal.
On a brighter note, I was keeping up with a Porsche GT4 in the corners today (he'ld easily pull on straights).
Let me know if pics of anything else are needed/helpful.
