Old 11-05-2016, 12:08 PM   #1
isotonic_uk
Drives: VW Golf MK7 2.0 TDI GT Bluemotion
Automatic locking has stopped working suddenly
Hi
Hoping someone can help me with this.
On my 2013 Golf MK7 2.0GT we have suddenly noticed that after getting in the car and going over 5mph the doors are not automatically locking. Its only suddenly stopped working and I dont know why, when I check the settings on the discovery media screen all seems ok and its still activated. I have also noticed that the boot is not opening unless I press the unlock key on the fob.
We don't think we have pressed anything, the screen isn't telling us of any issues with car so we are a bit stuck.
Does anyone know what this issue could be? Is it a known issue with this car?
Many Thanks
isotonic_uk is offline   Reply With Quote
Old 11-05-2016, 04:25 PM   #2
MarcA
MarcA's Avatar
Drives: Pure White 2013 Golf 2.0 GT TDi Mk7
As the boot isn't unlocking with the normal unlock function I would say that points to where your issue lies..
MarcA is offline   Reply With Quote
Old 11-07-2016, 08:52 PM   #3
isotonic_uk
Thanks I thought that but so toy know what it could be?
Sent from my SM-G930F using Tapatalk
Old 11-08-2016, 12:12 AM   #4
MarcA
MarcA's Avatar
It's not wet in the latch area is it ?
Old 11-08-2016, 01:04 AM   #5
The Fed's Avatar
Drives: 2016 Golf R
Didn't he say it does unlock with the fob?
Old 11-09-2016, 06:40 PM   #6
isotonic_uk
Yes it does unlock if you press on remote
Old 11-25-2016, 04:29 PM   #7
isotonic_uk
So I went to my local VW garage to get a cost and they want to charge 100 just to look at it! plus extra if they need to do anything on it!
I thought that was insane so left!
Anyway, I thought I would ask again whether its something I could resolve myself or whether it could be a fault within the electronics system.
I have checked through the discover media car settings sections and can confirm it is set ON for autolocking and I have also performed a reset through here for the door locking system but that hasn't made a difference.
Is this something that could be triggered by pressing a combination of buttons in the car or on the fob? I am not getting any faults appearing on the dash or car screen. If I press the button manually it works fine.
Any help on this would be most appreciated as it's doing my head in!
thanks
Old 11-26-2016, 11:29 AM   #8
MarcA
MarcA's Avatar
thanks
Does it use a speed sensor or something.. could be just that but nothe sure , not heard of this happening before.
Old 11-26-2016, 12:12 PM   #9
isotonic_uk
Unhappy
I don't believe it does. I think it must be a combination of pressing something which has caused it but even doing the reset on the automatic locking didnt resolve it.
I think I might give up and hope it sorts itself out...
Old 11-26-2016, 03:31 PM   #10
Geomets
Drives: Golf GTI Performance Pack
The electronics of a car act up weirdly if the battery of the car is going to die. I had a couple of situations (on an other car) and there were strange electrical early signs. Just a thought.
Geomets is offline   Reply With Quote
Old 11-28-2016, 09:33 AM   #11
isotonic_uk
Very weird the problem has seemed to resolve itself! I switched off automatic locking for a day and turned it back on after around 24 hours and it seemed to sort it. Thanks for everyone Input.
Old 11-28-2016, 10:36 AM   #12
MarcA
MarcA's Avatar
One to remember as I have same model as you.. thanks for posting back
Old 11-28-2016, 01:35 PM   #13
The Fed's Avatar
Drives: 2016 Golf R
It does use a speed sensor to determine when to lock the doors but I can tell you your wheel sensor is not bad. You would know it if it was.
And welcome to the wonderful world of VW electronics. I would put them second right behind Lucas.
