Old 05-14-2016, 02:49 AM   #1
BxGTI
BxGTI's Avatar
Drives: 2015 VW MK7 GTI, 2017 Audi A4 PP S Line2.0T
Cabin filter change warning
As I was changing my cabin air filter yesterday couple of things went wrong.
First when opening the glovebox to gain access to the filter housing when you push up on the glovebox tabs that stops the door from opening all the way down you have to be careful not to loose the rubber feet that will go flying around if you are not careful, also that arm/guide thingy that goes into the glovebox light switch, you want to lower it carefully, my dropped down too fast and the gear inside of it came out, I'm not sure if I'm missing another part because I can now hear the little plastic gear every time I open/close the door, now I have no memory on how smooth the glovebox opens up or if I'm being paranoid lol anyways I'll go at it again on Sunday and check but rubber stops are very easy to misplace I found them on the floor.
Sent from the Moon using Tapatalk
2015 Tornado Red GTI MK7
BxGTI is offline   Reply With Quote
Old 05-14-2016, 12:57 PM   #2
gillis.jordan
gillis.jordan's Avatar
Thanks for the heads up. I'm getting close to having to change mine
Sent from my SM-N920W8 using Tapatalk
gillis.jordan is offline   Reply With Quote
Old 05-14-2016, 03:02 PM   #3
o-iii
o-iii's Avatar
Drives: 2017 Silk Blue Alltrack
Same thing happened to me, lost that gear thing inside the body panel and now the glovebox is not damped when opened, it slams down. Hoping the dealer can fix it on my next visit. No idea where to find the part number for that thing!
o-iii is offline   Reply With Quote
Old 05-14-2016, 03:07 PM   #4
BxGTI
BxGTI's Avatar
Sure, no problem, the whole thing is super easy but these two things can give you a turn of events :-)
Old 05-14-2016, 04:21 PM   #5
gillis.jordan
Either of you guys running HR lowering springs. I've put out some feelers but no response. Shop said the springs he ordered for me will drop approx 1.5 to 2 inches which is I'm assuming the sport springs. I'm running 18x8 wheels with a 35 offset. 225 40r18 tire. Just wondering if there will be any rubbing issues
Old 05-14-2016, 04:56 PM   #6
BxGTI
BxGTI's Avatar
Wrong thread perhaps ?
Old 05-14-2016, 05:05 PM   #7
gillis.jordan
Posted in the right thread and have been reading since yesterday. Seems like people are only having problems when running 235s. Just wondering if anyone has a similar set up
Old 05-14-2016, 05:08 PM   #8
BxGTI
BxGTI's Avatar
Lol sorry I just figured that you meant to post on the wheel & tire section, I personally have WVR springs with ECS spacers no issues at all
Old 05-14-2016, 06:51 PM   #9
gillis.jordan
I went with HR to get a slight lower drop. Hopefully I have no clearance issues. There isnt a huge difference between the two {vwr} and {HR} but there's a bit
Old 07-04-2016, 02:28 AM   #10
The Fed's Avatar
Drives: 2016 Golf R
Threadjacking troll, how do you figure this is the right thread?
Old 03-27-2017, 05:37 PM   #11
AdamSheikh
Drives: 2015 MkVII VW GTI Autobahn
Exact same thing happened to me - was very close to ordering the part at my dealer but luckily found the gear under the floor mat in my back seat lol.
The part number for the damper is here: https://parts.vw.com/p/Volkswagen_20...5G1858309.html
Unfortunately need to buy the whole damper assembly rather than just the gear, etc.
2015 GTI | Autobahn | CSG | DSG | LP | OEM+ | Delivered June 2, 2014
S F L M K 7 / / /
A D A M S H E I K H . C O M
AdamSheikh is offline   Reply With Quote
Old 03-27-2017, 07:18 PM   #12
cldlhd
Drives: 2005 infiniti g35 coupe 6spd manual,2016 Golf SE
I lost one of the rubber things, actually forgot I lost it until I read this thread....
cldlhd is offline   Reply With Quote
Old 03-27-2017, 07:27 PM   #13
BxGTI
BxGTI's Avatar
Lol knowing that they were there and I still managed to lose one :-) right after taking those pictures
Old 03-27-2017, 07:31 PM   #14
Finglonga
Finglonga's Avatar
Drives: Mk7 Golf GTI Performance
First time you do it it always happens, that is because the little cog thingymajigger.....
Finglonga is offline   Reply With Quote
Old 03-27-2017, 08:01 PM   #15
eurospek
eurospek's Avatar
Drives: 2016 GTI Reflex Silver 6-spd
How often to change?
eurospek is offline   Reply With Quote
Old 03-27-2017, 08:47 PM   #16
breaking badly
Drives: Winnie Twister
Every year.
Get the Mann Frecious Plus filter.
Old 03-28-2017, 02:54 AM   #17
The Fed's Avatar
Drives: 2016 Golf R
When you first get into the car and the HVAC fan kicks in you'll smell a foul odor, like dirty socks. Could be 9 months, a year, or more. Impossible to tell. Depends on your climate and how much you drive.
