FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > GTI Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 03-07-2018, 04:55 AM   #375
AtlantaDad
Senior Member
Drives: Night Blue 2016 GTI Autobahn DSG PP LP
Quote:
Originally Posted by Gti jake View Post
Thats literally the best bang for your buck, I even suggest the $100 eBay dp and adding a cat and welding it into one piece. Thereís another thread for that, but glad youíre happy it! The 17930 does a great job
Yeah I don't really have a lot of drone (at least that I can tell), but I wouldn't mind a deeper tone. I jumped on the catted/resonated MAPerformance downpipe group buy. The 17930 is longer though, so I'm thinking of giving it a shot where the oem resonator is now. I know there's no "extra" benefit to the two resonators, but leaving the one in the downpipe can't hurt, right?
__________________
2016 GTI NB PP LP | Cobb AP w/ MAPerformance Stage 2 | MAPerformance Catted/Resonated DP | APR TIP | AFE drop-in w/ snow guard delete | 034 Dogbone INSERT | (coming soon) IE IC
Thou shalt read this first: http://www.golfmk7.com/forums/showthread.php?t=18297
AtlantaDad is offline   Reply With Quote
Old 03-07-2018, 05:26 AM   #376
Gti jake
Senior Member
Drives: GTI 6MT
I donít think itíll hurt, probably only weighs a few lbs and itís straight through
__________________
'16 GTI 6MT PM for NC/SC help with Installs & Fabrication
Baun Performance https://facebook.com/Baun-Performance-406768406417784/
YouTube Channel https://www.youtube.com/channel/UCu8...QYExsTq8fhQhmg
Gti jake is offline   Reply With Quote
Old 03-10-2018, 07:04 AM   #377
ashiun
Senior Member
ashiun's Avatar
Drives: 2015 GTI Autobahn w/ Leather, Tech, Lighting
So to sum it up:
Any aftermarket dp + stock GTI CBE = sounds good for 50% of people
Any aftermarket dp + stock GTI CSS CBE = raspy and drone to 99% of people
Any aftermarket dp + 18" 17930 or 17950 + any muffler = good for 99% of people
Brilliant. Just what I was searching for.
Quote:
Originally Posted by iNeedMorePSI View Post
Btw just did a quick video inside comparing closed vs open.
https://youtu.be/ip-WrgUFZyg
Outside no load revs. Will have to make one of the kids freeze in the dark for outside drivebys.
https://youtu.be/wV9kH9H1va0
Wow. I'm impressed. What a difference.
__________________
2015 Autobahn GTI 6MT Non-PP
5150 Cobb Tuned | DBV2 Intake, BMS TIP&TMD | CTS Turbo catted DP + Custom CBE | CTS Turbo IC | RS7 Beru spark plugs ¨
DIY TTRS Clutch | KW V1 Coilovers | Stoptech Slotted Rotors + HPS 5.0 Pads | 034 Mounts & Insert | Shifter Bracket + Bushings | Fuchs 75w Gear Oil | 17x9 Advanti S1 Storm & 245/45/17 Indy 500 ¨
ashiun is offline   Reply With Quote
Old 03-10-2018, 03:02 PM   #378
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
Question
Can vibrant res be done diy with clamps removing oem res or is this a must weld exhaust shop mod? obvs have to buy a pipe cutter. tx.
__________________
ED Moose E50 tune / ED DSG tune / Tomioka IHX475 Turbo / IE Intercooler / MAP cat+res Downpipe / Autotech HPFP
Diggs24 is online now   Reply With Quote
Old 03-10-2018, 03:05 PM   #379
AtlantaDad
Senior Member
Quote:
They are different lengths (4 inches I think?) so the vibrant would almost need to have a short section of pipe welded to it in order to take up the same length as the oem.
__________________
Old 03-10-2018, 03:18 PM   #380
Diggs24
Senior Member
Diggs24's Avatar
Ahh, for some reason I thought Vibrant was longer. Thanks.
__________________
Old 03-10-2018, 04:05 PM   #381
demi9od
Senior Member
demi9od's Avatar
Drives: 2017 GTI Sport DSG
The stock res body is 25", and IIRC you have about 31" of total pipe+body to play with between the hanger and midpipe clamp. My Magneflow install cost $60 and took the muffler shop maybe 30 mins.
__________________
ED ECU/TCU | ATP DP | IE IC | MF 12646 Res | Eibach Euro PKit | Koni Sports | ST RSB | SP Endlinks | IE Dogbone | RocEuro Arm | Revo Motor Mount | BFI Trans Mount | Helix Sub
demi9od is online now   Reply With Quote
Old 03-10-2018, 06:26 PM   #382
SugarMouth
Senior Member
SugarMouth's Avatar
Drives: 2016 GTI Autobahn DSG PP LP
It will look something like this. This is a shorter Timbre resonator.
__________________
SugarMouth is offline   Reply With Quote
Old 03-10-2018, 11:12 PM   #383
Cw6mt mKviGLi
Senior Member
Drives: 2017 GTi
I did two rear muffler swaps. One was a JCW rear on a friend's mini cooper S and another on a clubsport rear section for a mk7 gti. Mark and wrap the area with painters tape and use a sawzall. Have some fresh metal blades available. I got some straight cuts as if it was done on a professional bench mitter saw, straight and neat.
Debur the pipes and then use the clamps and it should be a nice, tight, leakfree seal.
Sent from my SM-G935T using Tapatalk
__________________
2017 Pure White VW GTi Autobahn 6MT
2016 Mythos Black Audi S3
2004 Magnesium Metallic Honda Civic EX 4D
Cw6mt mKviGLi is offline   Reply With Quote
Old 03-11-2018, 03:57 PM   #384
Diggs24
Senior Member
Diggs24's Avatar
Tore off heatshield. No change but worth a try. No drone just don't like the 3k rasp.
__________________
Old 03-13-2018, 07:05 PM   #385
ashiun
Senior Member
ashiun's Avatar
Regrettably I must say that I am part of the minority and it is both better and worse. Just shifted the points at where it drones, and now the drone is less "car-shaking rattly" and more "boomy bassy slight headache".
Seems to drone less under heavier throttle, more under light throttle.
Edit for clarity: This is after adding the Vibrant resonator. I'm just more sensitive to boomy bassy drone.
Edit 2: I was wrong. Exhaust shop welded in a 1793, not 17930. 1793 didn't do the job, 17930 did the job perfectly.
__________________
Old 03-13-2018, 07:36 PM   #386
Diggs24
Senior Member
Diggs24's Avatar
If that catback of yours has no resonator you absolutely should add one in.
__________________
Old 03-13-2018, 07:46 PM   #387
ashiun
Senior Member
ashiun's Avatar
The results I just mentioned are AFTER adding the vibrant resonator. It seems that I'm more sensitive to boomy, bassy drone than other types.
__________________
Old 03-13-2018, 07:50 PM   #388
Gti jake
Senior Member
Drives: GTI 6MT
What muffler are you running with it?
__________________
Old 03-13-2018, 07:54 PM   #389
Diggs24
Senior Member
Diggs24's Avatar
That sucks.
__________________
Old 03-13-2018, 07:57 PM   #390
ashiun
Senior Member
ashiun's Avatar
Flowmaster Super 10. I'm thinking of reverting to stock muffler but I'm getting the feeling it's just going to be even more bassy, somehow lol. Seems like every modification I make, it gets bassier. I wonder if there's any option to get rid of the bass, even if it's raspier. I'm so sensitive to bass that I wear open-can headphones with relatively "weak" bass signature (Sennheiser HD598), my friends tell me it sounds anemic, I say it sounds neutral.
How does the boomy bass not bother anyone else? Someone just posted a video on the facebook group of his setup and says it's not too bad, but the only thing I can think is "god damn that's bassier than mine, even".
Actually, upon further review, the drone isn't so bad accelerating. Above 4k it even sounds quite good. But the deceleration is absolutely KILLER. I don't know how I'm ever going to track with my eardrums rupturing everytime I'm decel from 5k.
__________________
Old 03-13-2018, 08:10 PM   #391
Gti jake
Senior Member
Drives: GTI 6MT
I think that’s you problem. I read the description and it’s a very short chamber muffler “not recommended for street use”
All of the off the shelf offerings for our cars are straight through design with fiberglass packing to absorb sound.
I use the Borla XS PRO and it fits works great in the cut out before the rear suspension. If anything it’s too quite for some people’s taste
As for the FB group 99% of them think catless dp to straight pipe sounds “awesome bro!” Lol
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
