FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Infotainment, Electronics, Navigation, Phone (Audio / Video / Electronics)
Reply
Thread Tools Display Modes
Old 09-13-2017, 01:55 PM   #1
euroadb
Senior Member
euroadb's Avatar
Drives: 2016 GTI SE w/ PP LP 6MT Pure White
Android Auto Issue?
Every time I use a voice command in Android Auto with "okay google" or simply pressing the mic button, it never returns to the media audio / radio once the command is complete. It will stay silent until I hit the mic button again twice to deactivate it. If you adjust the volume while it's silent, you'll see it's adjusting the volume of the voice or android auto, instead of media, even though the command is complete.
This is super annoying. Anyone have a fix for this? It was intermittent before, but now it happens all the time. This happened with my Nexus 6P, and is now happening with my new Pixel XL. So I think this is related to the head unit somehow not being able to detect when the command is complete.
Is there a factory reset on the infotainment somewhere?
euroadb is offline   Reply With Quote
Old 09-15-2017, 06:21 PM   #2
Blaylock1988
Member
Drives: Mk7 GTI
I have the EXACT same problem with my car and Android Auto with my Droid Turbo 2. No idea what the solution is. Android Auto has had multiple updates on my phone and the issue persisted.
Sent from my XT1585 using Tapatalk
Blaylock1988 is offline   Reply With Quote
Old 09-18-2017, 10:43 PM   #3
euroadb
Senior Member
euroadb's Avatar
It's such a PITA I wish there was a solution to this.
Old 09-19-2017, 01:57 AM   #4
MonkeyMD
Senior Member
MonkeyMD's Avatar
Drives: 2016 VW Golf Tsi S Manual
Same here. It's kind of hit and miss. Does it sometimes and sometimes not. No rhyme or reason.
MonkeyMD is offline   Reply With Quote
Old 09-19-2017, 05:55 AM   #5
Faceman
Senior Member
Drives: 2017 GSW S 4Mo
Happens to me on a rare occasion. Rebooting my S7 Edge usually resolves the issue.
Faceman is offline   Reply With Quote
Old 09-19-2017, 10:25 PM   #6
Nitsrik1976
Senior Member
Drives: MK7 R
It happens when in A Auto and listening to any media from the infotainment system such as radio or music held on the hard drive (jukebox). It resolves itself if you listen to Google play music but otherwise it gets stuck in SDS mode. These software bugs need to be fixed....it's shit and VW blame the phone...I've had it on all the O/S by Android....including Oreo!
Nitsrik1976 is offline   Reply With Quote
Old 09-20-2017, 02:57 PM   #7
euroadb
Senior Member
euroadb's Avatar
Quote:
Exactly. I don't even bother mentioning it to a dealer because you know they won't do anything about it and blame the phone. I asked if there's a firmware update for the infotainment and of course the answer is "no". But who knows if they even checked.
It makes sense that it would work as expected when listening to music via an app in AA, since the audio gets stuck within AA. Too bad I like to use satellite radio and micro SD for my music listening.
Also, what's "SDS" mode?
Anyway, I really wanna know wtf caused this because it used to work fine for me, then became intermittent, then just out of the blue it happens 100% of the time. Once in a while I can handle, but all the time is annoying beyond belief.
I tried factory reset on all settings on the infotainment, and also tried a hard reboot by holding down the power button for 10 seconds, but none of those worked. My next step would be to track down the fuse for the infotainment and pull that. Maybe it will help.
Is there any way to do a hard reset on the infotainment via a hidden menu?
Old 09-23-2017, 08:32 PM   #8
Nitsrik1976
Senior Member
Drives: MK7 R
SDS is speech dialogue system, ....Its a bug with the infotainment system. Basically VW don't do much about issues like this unless they are pushed. Try emailing VW boss at Wolfsburg. Before they do anything they need 5 complaints so you are best to contact the following with as much detail as possible. I've tried everything and can replicate it on demand, any reset is a waste of time as is resetting your mobile device.
Mr Matthias Mueller
buero.mueller@volkswagen.de
Old 03-13-2018, 07:39 PM   #9
euroadb
Senior Member
euroadb's Avatar
Just bumping my thread on the off chance anyone has found a solution...
__________________
IS38 | APR Stg. 2+ | DKM Stg. 2 clutch | USP Downpipe | DieselGeek Short Shifter | AirLift 3P Suspension
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
