FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Wheels / Tires / Suspension / Brakes / Chassis - Sponsored by The Tire Rack
The Tire Rack
Welcome to the Wheels and Tires section of GOLFMK7. This area is proudly sponsored by The Tire Rack.
If you are making a purchase from TireRack, please help support GOLFMK7 by clicking through to them with this link or clicking on the Tire Rack banner ad. Doing so helps give back to GOLFMK7 so we can keep this place running!
Reply
Thread Tools Display Modes
Old 03-13-2018, 05:58 PM   #52
pantsos
Senior Member
pantsos's Avatar
Drives: his wife crazy
Guys, i have a question.
TSI 1.8, my set up is 18x8 ET35 225/40/18.
I want to install DG springs, it will be ok with no rub and poke?
pantsos is offline   Reply With Quote
Old 03-13-2018, 08:19 PM   #53
nype
Senior Member
nype's Avatar
Drives: 2016 GTI Performance - DSG - Carbon Grey w/Leather
Re: poke
willtheyfit.com
Use GTI Austins wheels + spacers as the “flush” baseline (18x75 ET49). Factor in 15mm front and 20mm rear.
Rubbing shouldn’t be an issue since you’re going with OEM GTI tire size (circumference). But I don’t know how much the DG springs for the 1.8 drop, as compared to how they mildly drop the GTI.
nype is offline   Reply With Quote
Old 03-13-2018, 09:45 PM   #54
pantsos
Senior Member
pantsos's Avatar
Quote:
Originally Posted by nype View Post
Re: poke
willtheyfit.com
25mm-30mm for the Golf.
That’s more than enough for me.
Old 03-13-2018, 11:25 PM   #55
nype
Senior Member
nype's Avatar
If that’s what the math comes back with as far as “more poke than stock Austins”, then you’re going to poke 10mm past the fender on all corners.
Old 03-15-2018, 04:34 PM   #56
anjoVW
Senior Member
Drives: 2015 Golf TSI 1.8
Rubbing is the last thing to worry about.You'll have about 2-3 fingers worth of gap (close to Golf R stock). I'm on 235's with 18x8.5 ET45 and not close to rubbing. I planned on getting ST X coilovers (2 inches from 1.8t stock), and even on that setup I was told I won't rub.
__________________
Gloss Black Enkei TS10 18x8 ET45 | 235/40/18 Falken Pro G4 A/S Tires | DG Springs | Custom Vibrant Exhaust (Muffler Delete, Vibrant Tips, Vibrant 1790 Bottle Resonator)
anjoVW is offline   Reply With Quote
Old 03-15-2018, 10:52 PM   #57
BananaSlug
Senior Member
BananaSlug's Avatar
Drives: 2016 VW GTI SE DSG
Quote:
Originally Posted by Chuckable View Post
What did your alignment numbers turn out to be with this setup?
The pre-alignment numbers were:
Front
Caster: 7.7° both sides
Camber: -1.2° Left, -1° Right
Toe: .35° Left, -.25° Right
Rear
Camber: -2° both sides
Toe: -.10° Left, .05° Right
__________________
2016 CSG VW GTI SE DSG | LP | Johnson Ceramic Tint | Cobb Stage 2 by MAP | 034 Dogbone Insert | IE IC | MAP Downpipe /w GESI cat | aFe Air Filter | CTS TIP | Eibach Pro-Kit Springs | Bilstein B8 | Neuspeed RSe10 | Continental DWS06
BananaSlug is offline   Reply With Quote
Old 03-21-2018, 07:18 PM   #58
doolin64
Member
Drives: 2017 Golf GTI S & 2015 Ford F150
Well, I guess I made my first choice. I had the MSSKit in my cart but at the last minute, I switched to DG's. I know doubt could dial in the MSSkit to the exact height I wanted to see. Since I'm purely doing this for cosmetic reasons and enjoy my stock ride I stayed with the DG's. If I hate the ride, I'll move on.
doolin64 is offline   Reply With Quote
Old 03-21-2018, 07:29 PM   #59
White18
Member
Drives: 2018 GTI, 2008 HSV GXP, 2014 Mazda3
I am having DG installed tomorrow on my Mk7.5 GTI DSG DCC. I'll post photos and drop numbers.
__________________
OZ Hyper GT 18x8 ET45 | Pilot 4S 225/40-18 | ST 25mm Rear Swaybar | DG Springs | Audi R3 Brake Ducts | Powerflex Hybrid Bushing | APR Stage1+ | APR DSG | VW Homelink Auto-dimming Mirror | Blend Mount.
White18 is offline   Reply With Quote
Old 03-21-2018, 08:19 PM   #60
Clem604
Senior Member
Drives: 2018 GTI
Quote:
If you liked the ride with stock springs you'll like the ride with the DG's
__________________
2018 MK7.5 GTI
JB1-Majesty Intercooler-034 Dogbone Mount-K&N Drop In Filter-Ebay Turbo Muffler Delete- APR Turbo Inlet Pipe-Neuspeed Short Shifter-42 DD Shifter Bushings-ECS Clutch Bleeder Block-ECS SS Clutch Line-DG Springs-EBC Redstuff Pads-18x8 OZ Alleggerita-Riken Raptor 235/40/18
Clem604 is offline   Reply With Quote
Old 03-21-2018, 08:35 PM   #61
White18
Member
Quote:
That is what I was hoping for. Debated these or the H&R OE Sport Springs. Settled on the DG after reading tons of feedback.
__________________
Old 03-22-2018, 01:11 AM   #62
Clem604
Senior Member
Drives: 2018 GTI
For those of you wondering here are some pics of the car with the DG springs now after about 3000km.
The front drivers side
__________________
2018 MK7.5 GTI
Old 03-22-2018, 02:15 AM   #63
doolin64
Member
And here is a car with a 1000miles on a stock gti
Old 03-27-2018, 10:45 PM   #64
White18
Member
DG installed last week. All settled in. FTC front is 347.6, rear is 344.4 with both left and right sides measuring the same.
__________________
Old 03-28-2018, 02:22 AM   #65
doolin64
Member
Looks great! Mine go in on Saturday.
Old 03-28-2018, 02:33 AM   #66
pantsos
Senior Member
pantsos's Avatar
Installed my DG springs today. Very happy so far.
Noticeable difference in comfort, but nothing crazy.
Old 03-28-2018, 03:09 AM   #67
Bassman
Member
Bassman's Avatar
Drives: MK7 GTI
How does the DG springs feel compared to the stock suspension?
Bassman is offline   Reply With Quote
Old 03-28-2018, 03:34 AM   #68
pantsos
Senior Member
pantsos's Avatar
Quote:
I noticed they’re less bouncy, and a little bit more stiff. I would say 20-30% stiffer.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
