#1 |
Steering wheel off to left! Help!
Hey guys - my 40th anniversary GTI has developed an annoying issue - steering off to the left - my local VW dealership claims this is normal. This all came about after the car went in to have the turbo charger replaced - prior to this the steering was perfect.
The wheels have been alligned 3 times with no success - it is consistently off 5 to 8 degress off to the left with no crown on road (flat road). The car however still tracks dead straight with the wheel off to the left. It may not seem like much but with such sensitive steering it becomes extremely annoying and seems to wreck the driving experience. Please see the picture - how can I get this fixed?! Thanks in advance. ![]() Sent from my SM-G935F using Tapatalk Last edited by GTI40; 08-13-2017 at 05:25 AM. |
#2 |
Drives: GTI MK7 Autobahn, PP, DCC+LP, 97 F-150 4.6L V8 Location: Tennessee USA
This can be adjusted by a shop who knows how to work on cars.
It is part of an alignment check. They adjust them at the factory so they can adjust them at a dealer. You either need to meet with the Service Manager and based on his response decide what is next. Or, find a better dealer service dept. It can be easily fixed for a shop. My wife's Tucson had to be adjusted. I have had my Truck adjusted after an alignment. |
#3 | |
Drives: Winnie Twister Location: St. Olaf
![]() It's quite a simple job (by adjusting front and/or rear toe) getting the steering wheel straight. Guess they need to do it again. ![]() On a side note, I wonder if they thought they needed to remove or shift the subframe to swap the turbo. Actually that isn't necessary. . |
#4 |
Drives: GTI 6MT Location: Charlotte, NC
I'd never go back to that dealer, even Firestone was able to get my alignment right on the first try.
'16 GTI 6MT PM for NC/SC help with Installs & Fabrication Baun Performance https://facebook.com/Baun-Performance-406768406417784/ YouTube Channel https://www.youtube.com/channel/UCu8...QYExsTq8fhQhmg |
#5 |
Drives: 2016 VW Golf Tsi S Manual Location: Central Tx
+1 for Firestone. And you can get lifetime alignments
#6 |
Drives: '17 Wolfsburg 1.8T; '15 ZX6R; '00 KX250; '99 KX125 Location: Fremont, CA
Lol. That is pretty sad for the dealer in question
Watchdog Armory Racing AFM #725 Thanks to my 2018 Sponsors: JPH Suspension | AXO Racing | Armour Bodies | | EVLUTION Nutrition | Forcefield Armor | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
#7 |
Drives: 2014 MK7 2.0 GTTDI 3 dr Tornado red Location: Peterborough
easy diy fix you need to screw the drivers side track rod out a bit and the other side track rod in a bit the same amount so it does not upset the wheel alignment until the wheel is straight
#8 |
Drives: 2016 GTI DSG PP Location: UK (South Wales)
I had wheel alignment issues too on my MK7 GTI PP. I had a 4 wheel lazer alignment (hunter) done, but steering wheel was still off centre. Took it back and it was still off centre. Then I took it to a different alignment garage where they only aligned the two front with old fashion techniques (weights or some sort, no lazer) and then my steering wheel was bang on centre. It was so much cheaper too.
Thread Tools | |
Display Modes | |
