Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > MK7 vs......
Old 07-24-2018, 02:38 AM   #1
Twist
Twist's Avatar
Drives: 2018 Nightmare Golf
Vs. 450 whp 62/66 BMW 325i
Finally lost tonight. Was a GREAT run. I've ate alive stock twin *335is and even one that was Jb4.
Long story short, I am running one of the first versions of APR's highly aggressive 93 OCT HT tune (I hold at 26+ PSI, Peak 29-31). Obviously this was flashed a couple years ago and I've just kept it and made adjustments as they neutered base 93 maps quite a bit due to is20s popping like pop corn. (Stage two HT currently is 24-26 Hold to give a comparison).
I am FBO, with a franken/chopped - OE downpipe, but still on stock turbo (is20 on 26+ lbs). I run e30. My car is almost fully gutted. Weighs about 2850 pounds (4 door, manual, no lsd).
His car is a 335i with stock twins eliminated. He switched to big single turbo set up, 62/66 with e50, on a JB/MHD ethanol map/stack. He claimed 450 whp and car weighs about 3500..
Is20 torque is really, unbeatable in the price range from about 40-90 mph. My car goes from 40 to 65 mph in about 4/5 of a second. Each run I brake boosted 2nd, we did a 35 and a 40. At the start I jumped out about 2 cars each time, once we hit 4th (100ish mph) it was all over. His nearly 16mm bigger exducing turbo and 100+ hp pulled pretty steadily once we got into 4th past 100 mph. However I had him every time up to 4th gear. Not bad considering stock turbo and the massive difference in power. Thats p/w I guess...
Vids to come (waiting on him to send)
3 slow mk7s later..
Twist is offline   Reply With Quote
Old 07-28-2018, 07:13 PM   #2
cdubbgti91
Drives: Mk6 GTI (sold), Mk7 GTI
looking forward to the vids!
Mods: is38 Turbo/APR is38 tune/APR Downpipe/APR Carbonio Intake/APR Carbonio Inlet Pipe/APR Turbo Inlet Pipe/APR DSG Tune/APR Intercooler/APR Catch Can/APR Anti-Roll Springs/APR Pendulum Mount/IE Mahle Rods+Pistons/034 Dogbone insert/ECS Turbo Blanket/Continental ExtremeSportPlus Tires
YouTube:http://www.youtube.com/user/cbsantos91
cdubbgti91 is offline   Reply With Quote
Old 07-29-2018, 04:17 PM   #3
A2MK7
Drives: 2017 Mk7
Good run! can't wait to see the video.
2017 MK7 4DR MT
Stradified Pro Tuned
A2MK7 is offline   Reply With Quote
Old 07-29-2018, 04:55 PM   #4
Jose_Gti
Jose_Gti's Avatar
Drives: Golf GTI MK7
MT APR stage II APR Down Pipe. APR Intake. RS7 plugs/RS3 Coil Packs. 034 Dogbone. APR short shifter full system. ECS Clutch Bleeder Block. Billy Boat Resonator. TTRS Clutch kit. UBQ unibrace and Neuspeed sway bar. APR Intercooler + Apr boost hoses, apr turbo inlet pipe.
235/40ZR-18 Michelin Pilot Sport A/S3. BMS pedal tuner.
Jose_Gti is offline   Reply With Quote
