Old 06-13-2018, 07:36 PM   #18
Gogo GTI
Gogo GTI's Avatar
Drives: 2017 GTI Sport DSG
Excuse the noobish question but what actions can be taken with oil analysis data? For example, letís say the presence of nickel keeps going up indicating a serious issue. What can I do about this. Is this something I should document with the dealership ahead of time?
Im mainly doing the oil analysis to get a baseline before I go stage 2 in about a year. If my next oil analysis isnt great, Iíll forego the tune. But what would I do next?
Gogo GTI is offline   Reply With Quote
Old 06-13-2018, 07:52 PM   #19
Wrath And Tears
Drives: 17 Sport DSG
Dealership would call it normal wear and tear. There is unfortunately not much you can do about it, except switch oil like was mentioned.
EQT ECU/TCU Tuned, Baun Performance FMIC, 2Slowvw Air Scoop
Wrath And Tears is offline   Reply With Quote
Old 06-15-2018, 07:09 AM   #20
Tigsel
Drives: 2016 Golf R 6MT
Dealer won't do anything until you have an actual problem, which you may never have. For now shorten oil change intervals to 5k and use better oil.
Originally Posted by Frank Reynolds View Post
I lubed it up really well. I got it in eventually but it was nothing like how they show in the video. Usually the case, but I'm friggin sore still!
Tigsel is offline   Reply With Quote
Old 06-15-2018, 05:49 PM   #21
Gogo GTI
Gogo GTI's Avatar
Any recommendations on a better oil?
Old 06-15-2018, 07:40 PM   #22
Cameron1292
Cameron1292's Avatar
Drives: Mk7 GTI SE DSG Pure White
Gonna get my oil tested from Blackstone. Hopefully next week send the kit in. 5k miles with liqui moly 5w40
Sent from my ONEPLUS 5T using Tapatalk
Stratified Automotive Tuned---Stratified Automotive DSG Tune---Injen Evo Intake---VWR springs---RS7 plugs---MAPerformance catless downpipe---Custom turbo back with Magnaflow Magnapack---Majesty Twin cooler Intercooler---ECS Tuning Carbon fiber rear wing---Aerofab v1 Splitter---19x8.5 Alzor 020 with General Super Steel 595 235/35/19
Cameron1292 is offline   Reply With Quote
Old 06-15-2018, 08:03 PM   #23
tpellegr
tpellegr's Avatar
Drives: 2016 GTI S (non-PP) 6MT
5W40 or 0W40 2050 LiquiMoly seems to be a fairly popular choice. The 0W is higher quality base stock but not technically VW502 approved. See below for additional reading.
https://www.golfmk7.com/forums/showthread.php?t=39407
2016 GTI S 6MT | Build Thread | APR Stage 1
tpellegr is offline   Reply With Quote
Old 06-16-2018, 08:25 AM   #24
Tigsel
1- Ravenol SSL (best)
2- Liqui Moly 2050
3- Motul 8100 X-Cess
4- Castrol Edge 0w-40
Old 06-16-2018, 09:45 AM   #25
Cameron1292
Just make sure its approved by vag502 not just recommended by the company for warranty reasons. I use liqui moly 5w40 leichtlauf high tech. Vag 502.00 approved.
Old 07-12-2018, 04:05 AM   #26
AZ GTI
Drives: 9th VW: 16 GTI SE
I had my Motul Xcess analyzed at 15k. Copper and Nickel were slightly elevated still.
That’s the third change and they definitely didn’t say I could go longer. So it’s 5k for me.
I will maybe try Molygen or standard Liqui Moly 2050.
16 GTI SE-Worked IS38 Turbo by G Pop, Eurodyne ECU/TCU tune, IE Intercooler, APR Intake, MAP catted/resonated DP, CTS inlet, ECS turbo muffler delete, RS7 Plugs, 034 Mounts, ED springs, Eibach RSB, Superpro Rear Links, 235/40 PSS
AZ GTI is offline   Reply With Quote
Old 07-12-2018, 04:48 AM   #27
AspektZA
Drives: GTI Mk7 SE DSG
Any oil that meets all of the below specs:
VW502 / Porsche A40 / MB 229.5 / BMW LL-01 / FIAT-Ferrari-Maserati (H2/Z2/etc)
Is going to perform identically over the life of an engine in terms of wear protection.
No amount of boutique, 100% Group IV stock oil is going to affect anything meaningful.
Use OE filters, a good oil, and you'll have no problems.
I personally use Pennzoil Euro 0w-40 ($23/5qts) and Mahle filters.
AspektZA is offline   Reply With Quote
Old 07-12-2018, 09:28 AM   #28
Gogo GTI
Gogo GTI's Avatar
Thatís the third change and they definitely didnít say I could go longer. So itís 5k for me.
What kind of numbers are you seeing with cooper and nickel?
Old 07-12-2018, 05:27 PM   #29
1 and 5
ED Moose E50 ECU tune / ED DSG Stage 2 tune / Tomioka IHX475 Turbo / IE IC / MAP cat+res DP / Autotech HPFP / PR 450 LPFP / Uni TIP / EQT TMD and Pipes / NT-05s on Asstins / Full Stealth Mode
Old 08-08-2018, 03:19 PM   #30
Chuckable
Anyone get a used oil analysis?
Hereís mine:
Chuckable is offline   Reply With Quote
Old 10-09-2018, 05:12 PM   #31
zero10
Drives: 2017 Golf
Just got my second UOA results, my copper still seems a bit high? But things look good otherwise. I'm going to stick with the SP-III for a while since it's 504.00 rated and I'd like to do extended change intervals on it once the warranty is up.
zero10 is offline   Reply With Quote
Old 10-10-2018, 03:04 PM   #32
reverend_sean
Drives: 15 GTI
I should have an interesting comparison for us all in a few months. I have done 2 Blackstone analysis with Liqui Moly Leichtlauf High Tech 5w-40. First sample was pulled at 40k mi with 6k mi on the oil; second one was pulled at 45k mi (obviously 5k on the oil). Both came back clean with no elevated metals at all.
At that point I decided that since I was going to be track driving more often, I wanted to just run less expensive oil and switch it more often (depending on the number of track days). I used Castrol Edge 5W-30 on that fill up and plan to switch it out at 5k (I have about 1500 miles left to go to at this point). I will do another Blackstone analysis and we can see if there are any differences between my Liqui Moly results and the regular Castrol synthetic (non-VAG502).
reverend_sean is offline   Reply With Quote
Old 10-10-2018, 03:56 PM   #33
LurpyGeek
Drives: 2016 Volkswagen GTI S
As mentioned above, not sure if there is much I could do if there was a problem, but I guess this gives some peace of mind.
Car has 40,000 miles on it.
LurpyGeek is offline   Reply With Quote
Old 12-02-2018, 04:29 PM   #34
Huntermike
Guest
Posts: n/a
Castrol Edge 0w-30 A3/B4 in use for 5600 miles, 29,900 car miles when drained. Tons of life left and I was surprised to see the iron number so low. 90% highway miles, easy on the throttle until oil hits 180F then whatever.
Refilled with Pennzoil Platinum Euro 0w-40 and a VW filter.
