Old 11-23-2014, 12:58 AM   #1
Jasper
Drives: 2015 VW Golf S 1.8T TSI
Anyone get a used oil analysis?
Hey all.
With all this long life oil and huge OCI's, does anyone do used oil analysis? It's fairly affordable with Blackstone Labs for $25/sample. I used to do it for a while with my previous car just to see if everything inside was ok. (It was great although fuel % was higher than normal due to the engine being GDI)
So does anyone do it?
Jasper is offline   Reply With Quote
Old 11-23-2014, 01:57 AM   #2
kyoo
Drives: Not GTI
in for this. do this for all my cars
kyoo is offline   Reply With Quote
Old 11-23-2014, 03:58 AM   #3
phaphaphooey
Drives: MK7 GTI/Lotus Evora/Alfa Romeo 4C/Porsche C2S
Someone posted one both here and on vortex awhile back. It suggested an early change for the first one and then 10k oci after that was probably fine with a quality oil and filter iirc.
phaphaphooey is offline   Reply With Quote
Old 11-25-2014, 05:10 PM   #4
rgiskard
Drives: 2015 GTI S
I did this, with Blackstone, for my previous car, a Jetta TDI. Good info.
Plan on doing it as well with the new GTI.
2015 GTI, S, DSG, Night Metallic Blue | Stock: CAI & DV+ removed 10/2/18
rgiskard is offline   Reply With Quote
Old 11-26-2014, 10:53 PM   #5
joema
Drives: 2015 GTI DSG Autobahn. Previous: 2010 GTI APR Stg2
Originally Posted by Jasper View Post
....With all this long life oil and huge OCI's, does anyone do used oil analysis? It's fairly affordable with Blackstone Labs for $25/sample....
I have 6,700 mi on my 2015 GTI with APR stage 1. I've had the oil changed twice, and had Dyson analysis and professional interpretation done both times. First change was at 2,889 mi on the oil, 2nd change was at 3,781 mi on the oil.
Analysis and interpretation indicated the early change was needed both times, and he recommended trying a different oil. Initial analysis was on the factory fill, presumably Castrol. Second analysis was on dealer-serviced Castrol Syntec 5W-40.
I'm now running Pennzoil Ultra Platinum 5W-30, and will have it analyzed in about 3,000 more miles.
See attached .PDF which he gave the OK to post.
joema is offline   Reply With Quote
Old 11-27-2014, 05:50 AM   #6
TecklenburgVW
TecklenburgVW's Avatar
Drives: 2015 Golf R w/ Tech Tornado Red
Joema,
Do you do the sample collection on your own or have a mechanic collect the sample?
I went to www.testoil.com and it appears they work directly with mechanic shops. I failed to see where they provide sample collection to general public.
TecklenburgVW is offline   Reply With Quote
Old 11-27-2014, 06:17 AM   #7
TecklenburgVW
I'm looking into Blackstone-Labs, Testoil.com and Amsoil Oil Analysis services. Anyone work with these companies or any others that I failed to mention?
Old 11-27-2014, 02:36 PM   #8
joema
Originally Posted by TecklenburgVW View Post
Joema,
I use Dyson Labs; they provide a sample collection kit and pre-paid mailer. You can collect it yourself or have the mechanic do it. The analysis includes an extensive narrated audio commentary as he interprets each item on the results. It also includes unlimited follow-up questions via email, which are typically answered within 1-2 hours: http://www.dysonanalysis.com/
Old 11-27-2014, 04:36 PM   #9
phaphaphooey
Blackstone is popular on BITOG but Joema has had a great experience with Dyson.
Joema, thank you for continuing to share your knowledge with the rest of us. Was planning on M1 0W40, Castrol 5w40, of Shell T6 5w40 as the change as I thought that the engine would benefit from a heavier oil than a 30 weight although I know that some of those oils, particularly the M1, are very light 40s that quickly shear into the 30 weight range. Have you posted about this on BITOG? If there is a place where I can keep up with your oil exploits I would like to know it.
Old 11-28-2014, 01:20 AM   #10
joema
Originally Posted by phaphaphooey View Post
...Was planning on M1 0W40, Castrol 5w40, of Shell T6 5w40 as the change as I thought that the engine would benefit from a heavier oil than a 30 weight ...Have you posted about this on BITOG? If there is a place where I can keep up with your oil exploits I would like to know it.
I'll post on BITOG as soon as I can. In the interim I suggest MkVII owners change oil at more frequent intervals, esp. if modified.
Old 11-28-2014, 06:10 AM   #11
TecklenburgVW
BITOG?
I'm a n00b.
Old 11-28-2014, 04:44 PM   #12
joema
http://www.bobistheoilguy.com/
Old 05-30-2018, 06:49 PM   #13
Gogo GTI
Gogo GTI's Avatar
Drives: 2017 GTI Sport DSG
Just got the results of my first oil analysis from Blackstone Labs. This is my 2nd oil change. Analysis done at 20K miles and I'm using 10K interval, did not analyze the first oil change. Copper, nickel and titanium seem to be slightly above normal but they say it's nothing to be concerned about. Will be keeping an eye on it. It seems like the elevated copper levels are bit common. Any thoughts?
2017 GTI Sport DSG
JB1 for over 12,000 miles
Dealership oil changes using 5W/40 Castrol
91 Octane
Daily driver, medium to heavy on the throttle everyday. Typical day I go WOT often and it's mostly freeway driving. I don't push it beyond that too often.
Gogo GTI is offline   Reply With Quote
Old 05-31-2018, 11:27 PM   #14
zero10
Drives: 2017 Golf
UOA looks good! I'm creeping closer to my second oil change (30,000km) and will be doing analysis on it just like my first. I am pretty sure the copper is just leeching out from the oil cooler and other new parts, the nickel is interesting but it is really low so I wouldn't worry. If it started increasing... then I'd worry.
zero10 is offline   Reply With Quote
Old 06-11-2018, 08:26 PM   #15
Shortybdub
Shortybdub's Avatar
Drives: My wife crazy
Copper is from bearing break-in, brazed parts in contact with oil, and oil additive, no worries. Nickel is a piston wrist pin alloy and should be in the low single digit ppms for our cars. Keep an eye on this.
Shortybdub is offline   Reply With Quote
Old 06-12-2018, 08:34 AM   #16
Tigsel
Drives: 2016 Golf R 6MT
I say Copper and Nickel are a little too high for 20k. I've spent a little fortune on oil analysis on EA888 engines. At 20k Copper should be around 9-12 and Nickel around 1-2. Use a better oil and do another test in 5k.
Originally Posted by Frank Reynolds View Post
I lubed it up really well. I got it in eventually but it was nothing like how they show in the video. Usually the case, but I'm friggin sore still!
Tigsel is offline   Reply With Quote
Old 06-12-2018, 06:34 PM   #17
Gogo GTI
Gogo GTI's Avatar
Thanks for the advice guys.
