Old 08-26-2019, 01:53 AM   #1
Proxima
Proxima's Avatar
Drives: 2001 VW New Beetle 1.8 turbo, 2019 GTI SE MT
Engine bay cleaning
Any tips, cautions or advice on cleaning the engine bay? I have Youtubed this as see lots of variation on what to do and what not to do.
My GTI was very gritty from the dealership. I should have had them detail it up for me but I didn't. It looks as if it was left outside and a sandstorm hit the area or something.
Thanks and advance!
Proxima is offline   Reply With Quote
Old 08-26-2019, 03:05 AM   #2
jimlloyd40
Drives: 2018 Golf GTI SE
Just be very careful on the electrical parts.
jimlloyd40 is offline   Reply With Quote
Old 08-26-2019, 03:14 AM   #3
sandmangti
sandmangti's Avatar
Recently I washed mine.
Not first time.
I use aluminum foil and cover the electrical box. Wrap it around top. Also wrap alternator as best I can. Mainly cover top side.
They I snow foamed the engine and under hood. Used small horse hair detail brush to agitate. They used wet micro fiber to wash big flat spots and underside of hood. Wipe down hoses and all I can reach. They used light pressure power wash and rinsed.
They used blower to remove water. Dry with micro fiber also. Start engine and run for 5-10 min.
Let dry over night. They spray down with detailer spray or what you like. Pearl of 303 are good option. Let sit. Then wipe off extra.
sandmangti is offline   Reply With Quote
Old 08-26-2019, 05:02 AM   #4
JerseyDrew77
JerseyDrew77's Avatar
Drives: 2016 TR GTI S 6MT
Why even bother cleaning it when it's just going to get dirty again.
Breaking V8 hearts and dreams - DBV2 Journal Bearing V2 Turbo w/TMD protuned by Ed (EQT) | CTS Intercooler (Direct Fit) | COBB Intake | MAP 3 inch Catless DP | AWE Track CBE | ECS & EQT Charge Pipes | BMS TIP | Spulen OCC | AEM 5 Bar w/APR Boost Tap | Bosch 4 Bar | NGK Racing Plugs (Heat Range 9) | Fluidampr | SuperPro Mounts | DKM Twin Disk Stage 3 Clutch | Autotech HPFP | PR Stage 3 LPFP | PR Fuel Line | Torqbyte PM4
JerseyDrew77 is offline   Reply With Quote
Old 08-26-2019, 02:14 PM   #5
sandmangti
sandmangti's Avatar
Some people look like they drive on gravel roads from their engine pics, but if I wash once a year it stays good for me. 4 years old my engine looks new.
Why wash? Just a personal thing. Only I see but I enjoy.
Old 08-26-2019, 04:47 PM   #6
mopar22
Drives: 16 GTI SE
I just wash without covering anything up since in todays world almost everything is watertight as long as you don't blast it with water. I'm a detailer at a dealership and had zero issues
mopar22 is online now   Reply With Quote
Old 08-26-2019, 06:25 PM   #7
swcrow
swcrow's Avatar
Drives: MK7.5 GTI SE
Nice. This is essentially what I'm going to do on "shower" setting with garden hose.
Uni St2 ECU/TCU; Baun FMIC/DP/MP and a partridge in a pear tree....
swcrow is online now   Reply With Quote
Old 08-26-2019, 06:28 PM   #8
DThissen
Drives: 2015 GTI Autobahn
This. I used to detail cars and aslong as you're not blasting anything directly it should be okay. That said, I always took care around anything electrical and held the pressure washer a good 10+ inches away. If you have access to a leaf blower (or compressed air) you can use that to blow most of the excess water away.
DThissen is offline   Reply With Quote
Old 09-26-2019, 03:10 AM   #9
GolfRRRR
Drives: MK7 Golf R
This is what I tell myself about brushing my teeth or wiping my ass...j/k or not
Engine bays are hurricane's in rain storms, so just don't high pressure wash electronics...the 'shower' setting on a hose is fine.
GolfRRRR is offline   Reply With Quote
Old 09-26-2019, 04:07 AM   #10
jimlloyd40
Pride for one thing and it makes finding an oil leak easier. That's like saying why bother washing or waxing the car.
Old 09-26-2019, 05:34 AM   #11
JWTS
Drives: GTI/Alltrack
It's funny, a friend's college-age son asked this about cleaning his toilet.He was 100% serious....
I mean, couldn't this be said about pretty much anything?
I clean it because it I need to work on the engine (whether it's replacing an air filter or cleaning the valves), there's not dirt all over the place flying into an open engine. And, as mentioned, it makes spotting leaks a lot easier.
JWTS is offline   Reply With Quote
Old 09-26-2019, 07:11 AM   #12
eajr
eajr's Avatar
Drives: '15 GTI SE 6MT
I am very much into detailing (not a professional though) and I clean my engine bay about twice a year, maybe 3 if its really bad. I usually just cover my battery with a plastic grocery bag, and that's it. I first spray everything down with an APC (I use Mean Green Auto+Garage, a gal at Walmart is like $6), and scrub with various brushes where it needs more attention. I then spray it down with my pressure washer (yea I know....), constantly moving the stream and not focusing on any specific area. If it requires more cleaner, I will do it again in that area, but it usually doesn't. I finally blow dry the bay with my leaf blower. I also do underneath the hood as well. I have never had not one problem using my method, not 1 light or any malfunction of any kind.
eajr is offline   Reply With Quote
Old 09-26-2019, 10:45 AM   #13
Carlosfandango
Carlosfandango's Avatar
Drives: 2016 3Dr Mk7 GTi DSG Carbon Grey
Take a look at this guys YouTube channel, hes very knowledgable on everything detailing.
https://youtu.be/QmSHfoHmQmY
Carlosfandango is online now   Reply With Quote
Old 09-26-2019, 11:31 AM   #14
Beju
Drives: 2019 GTI Rabbit Ed, Mazda CX-5, Ducati Monster 696
That's how mine was too. I picked it up the day it showed up at the dealership in mid-June. I figured it got hit with a sandstorm somewhere in Texas or northern Mexico.
Sent from my ONEPLUS A6013 using Tapatalk
Beju is offline   Reply With Quote
Old 09-26-2019, 11:40 AM   #15
JerseyDrew77
Pride or more like OCD?
And that is not the same. The only time I can see cleaning an engine bay would be for a car show.
Old 09-26-2019, 12:59 PM   #16
riceburner
Drives: 2015 GTI SE
Not first time.
This method 100% is the way to go. Some keys are the pressure washer because it will force things off your engine however it doesn't use as much water as just 'hosing it down'. Although that also means you need to be even more careful around electrical parts. I don't have a presure washer yet so i use my hose setting on 'mist' lol.
https://www.golfmk7.com/forums/showthread.php?t=55314
2016 GTI SE, Performance Pack, DCC, Manual
2012 GTI, K04, DSG
2015 GTI SE, Manual, stage 1 and bolt ons - long gone.
riceburner is offline   Reply With Quote
Old 09-29-2019, 03:05 AM   #17
@Autobahn
@Autobahn's Avatar
Drives: '18 Golf R, '08 R32
APC is key as you have mentioned to break down oil/grease.
@Autobahn is offline   Reply With Quote
