Old 05-14-2014, 02:21 AM   #1
Finepics
Drives: Golf Mk7 1.4 TSI 122ps DSG
VW oil compatibility chart
Found a VW pdf chart for VW502 00 and VW505 01 oil compatibility. Updated chart has now been published. Unfortunately the pdf is too big for the forum rules to post for direct download so have linked to it instead here:
https://www.audiusa.com/content/dam/...e-Bulletin.pdf
VW Golf MK7 Trendline 1.4 TSI
122ps|DSG|BlueMotion|Pacific Blue|15" Zirkonia Alloys (to be upgraded as soon as money allows)|AudiotecFischer Match DSP & Sub
Last edited by Finepics; 03-11-2016 at 07:06 AM. Reason: Updated chart added as link
Finepics is offline   Reply With Quote
Old 05-14-2014, 10:25 AM   #2
GC854
GC854's Avatar
Drives: GTD in Carbon Steel
Originally Posted by Finepics View Post
Found a VW pdf chart for VW502 00 and VW505 01 oil compatibility. It's dated 2006 but is still relevant for today.
Cheers. But folks better check their handbooks as Mk7 diesels require VW507 00
GC854 is offline   Reply With Quote
Old 05-14-2014, 11:13 AM   #3
Finepics
Thanks for that. VW507 00 spec is a 5W-30 oil with extended life.
Old 05-14-2014, 04:05 PM   #4
Talk-torque
Talk-torque's Avatar
Drives: VW Golf GTi 2016 + Westfield 2Lt. Zetec missile
The VW507.00 spec. 5W-30 oil is required for all current top end turbo engines in the VAG ranges, on the extended service schedule. They are all delivered with the engine filled with that oil. Used to be that diesels and petrols had different spec. oil, but the top spec. synthetic seems to cater for them all now.
Roger.
Tungsten Silver 5 Door GTi DSG with Carplay & Rear Airbags. Collected 02-04-2016
Talk-torque is offline   Reply With Quote
Old 05-14-2014, 04:53 PM   #5
testcard
testcard's Avatar
Drives: Golf MK7 GTD
...and about the same price as a single malt.
Mk7 3-door GTD. Carbon Steel Grey | Dynaudio | Pano roof | Keyless
testcard is offline   Reply With Quote
Old 05-14-2014, 05:07 PM   #6
GC854
GC854's Avatar
X2. What am I smiling about, it's too true!
Old 05-14-2014, 05:18 PM   #7
testcard
testcard's Avatar
Goes down well with a splash of Ginger Ale. And you don't need another for 18,000 miles.
Old 05-14-2014, 05:30 PM   #8
Finepics
I feel a Laphroaig coming on!!
Old 06-04-2014, 08:38 AM   #9
mrlapou
Drives: Mk7 R DSG
This may help.
mrlapou is offline   Reply With Quote
Old 08-03-2014, 11:16 PM   #10
singleminded
Drives: VW, BMW, Subaru
So there's no confusion: the owners manual for the US GTI (gasoline engine, of course) does NOT spec 507.00. It specs 502.00 This is also stated on a sticker in the engine bay.
The manual also specs EITHER 5W-30 OR 5W-40.
singleminded is offline   Reply With Quote
Old 11-11-2014, 04:19 AM   #11
Pedro
Drives: GTI MK7
I prefer using the 5W-40 to minimize the oil consumption
Pedro Mogollón
2009 Jetta 1.8T: APR Stage 3+ 13.2
2012 Seat Leon 2.0 TSI 6MT: APR stage 3+ 12.19
2013 Seat Leon 2.0 TSI DSG: APR K04 12.09
2015 VW GTI 2.0 TSI DSG: APR Stage 2 12.6
Pedro is offline   Reply With Quote
Old 11-24-2014, 07:17 PM   #12
ReadTheBook's Avatar
Drives: '90 Cabby, CSG '17 GTI Sport
Well, looks like I'll just keep buying 0W-40 Mobil1 by the jug...My BMW takes the same oil as our new Golf since it meets the spec.
ReadTheBook is offline   Reply With Quote
Old 06-05-2015, 03:33 PM   #13
Alunakis
Drives: Skoda Octavia 3 1.4 TSI 140HP
Hello,
If I have in engine Castrol oil with VW 502 00 specification (fixed service interval), can I add Castrol oil VW 504 00 specification (variable service interval) to get „max” on dipstick?
If in the engine is Castrol oil with VW 502 00, can I add Mobil 1 ESP, same 5W30, with VW 502 00 to get „max” on dipstick? The additives are different? Problems may occur?
Thank you for answers.
Alunakis is offline   Reply With Quote
Old 06-11-2015, 06:22 PM   #14
Ecapskcab
Drives: MKVII GTI
I just used Schaeffer Supreme 9000 series oil. VW 502 certified. Everything going great thus far.
Ecapskcab is offline   Reply With Quote
Old 06-26-2015, 12:11 AM   #15
TecklenburgVW
TecklenburgVW's Avatar
Drives: 2015 Golf R w/ Tech Tornado Red
Has anyone tried this Oil Additive by Liqui Moly:
http://www.ecstuning.com/Volkswagen-...ine/ES2788486/
Ceratec Oil Additive
Volkswagen Golf VII R 2.0T Gen3
Performance additive for longevity of metal engine/transmission components. 300mL
Ceratec is a high quality ceramic wear protection product which is safe for use in all engine oils. It reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Ceratec reduces direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. The chemicals in this specially-formulated product adhere to metal surfaces to reduce internal wear and friction, giving you peace-of-mind and saving you costly repairs in the future. Treats up to 6 quarts of engine oil and provides up to 30,000 miles of protection under normal driving conditions.
*Note: Not suitable for use with wet clutch applications or limited slip differentials. Great for use in vehicles with high pressure, cam-driven fuel pumps or engines making noise upon start-up.
TecklenburgVW is offline   Reply With Quote
Old 03-11-2016, 06:53 AM   #16
This is the most current VW/Audi Oil Spec Sheet for 1997-2016 models.
Old 03-11-2016, 06:57 AM   #17
TecklenburgVW
+1
Sent from my SPH-L720T using Tapatalk
