FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Reply
Thread Tools Display Modes
Old 09-09-2019, 12:01 AM   #1
AsymmetricKururin
Junior Member
Drives: 2017 Golf R, cosmetic mods only
Battery disconnected, now have malfunctions
I have a MK7 Golf with low mileage, no prior electrical or electronic component issues.
While attempting to install a battery maintainer, the negative battery cable popped off the post and caused a spark when it touched back down. I decided to not risk other problems while I was fighting with the leads on the battery maintainer so I disconnected both battery cables and covered the battery with a heavy cloth until the leads and cables were secured.
Once I reconnected the battery and started the ignition I had a bunch of Malfunction Indication Lights appear in the instrument cluster. I scanned all the control modules with my VCDS and found that now I have errors on these modules:
01 (Engine) --> multiple databus errors concerning the accelerator and brake fault statuses
03 (ABS Brakes) --> steering angle sensor
10 (park/steer assist) --> 2 databuses received an error message
13 (Auto Dist. Reg) --> 4 databus error or implausible messages
3C (lane change) --> 1 databus error message
44 (Steering assist) --> steering angle sensor not initialized
A5 (Frt. Sens. Drv. Assist). --> databus received error message
Does anyone know from personal experience with a Mk7 VW, not mere speculation if these messages are likely to go away on their own if I take a 20 minute drive to allow the car to re-learn or re-calibrate something? Or do these control modules need to be manually re-initialized due to the temporary loss of power? Or does this combination of DTCs indicate that the spark on the battery terminal actually damaged some of the control modules?
AsymmetricKururin is offline   Reply With Quote
Old 09-09-2019, 12:15 AM   #2
Gti jake
Senior Member
Drives: GTI 6MT
They should all clear within a few hundred feet of driving
__________________
No private messages please, I will only respond to emails jlbaun26@gmail.com
-Jake
Gti jake is offline   Reply With Quote
Old 09-09-2019, 02:33 AM   #3
Raguvian
Senior Member
Drives: Golf Sportwagen
All the lights on my dashboard were lit up when I reinstalled my battery. They went away by the time I pulled out of my parking lot.
Raguvian is offline   Reply With Quote
Old 09-09-2019, 03:26 AM   #4
George Ab
Senior Member
Drives: GTI MK7, BMW E90
From my personal experience. If you disconnect the battery after 10 to 15 minutes of the car being on, all failures will reset about 30 seconds after starting car. If the battery is disconnected withing the first ten minutes, I get a communication error, engine light will go on and stay on. You then need to reset fault code/s with VCDS.
George Ab is offline   Reply With Quote
Old 09-09-2019, 04:14 AM   #5
Senior Member
Drives: 2018 Golf GTI SE
Quote:
You can reset fault codes with a cheap OBD2 reader and the Torque app. No need for VCDS for just resetting codes. VCDS is great for lots of things but I didn't want other people to think that you have to have it to clear codes.
jimlloyd40 is offline   Reply With Quote
Old 09-09-2019, 06:21 AM   #6
Carlosfandango
Senior Member
Carlosfandango's Avatar
Drives: 2016 3Dr Mk7 GTi DSG Carbon Grey
I recently disconnected the battery when I removed my steering wheel, I got all of the faults and lights you described but they do all go and everything goes back to normal after a bit of driving, I did however still have a couple of faults logged (no dash lights) so had to clear them with VCDS, they didnít cause any problems however and could have been left logged until such time they could be cleared, at a shop on your next service for example.
Carlosfandango is offline   Reply With Quote
Old 09-11-2019, 08:05 PM   #7
YamR1rider
Senior Member
Drives: 2017 GTI Sport DSG
What everyone else said, just drive it, the lights will go out, usually within a few feet. The spark putting your lead back on isn't an issue -they do that.
Also you will have to set your clock.
YamR1rider is offline   Reply With Quote
Old 09-12-2019, 03:32 AM   #8
Carlosfandango
Senior Member
My clock set it self, must have done it through the GPS!
Old 09-13-2019, 05:18 PM   #9
caleb.mk7
Senior Member
caleb.mk7's Avatar
Drives: 2016 DSG
If you don't want to drive it, you can also turn the wheels all the way to the left and then all the way to right while stationary to clear the codes.
caleb.mk7 is offline   Reply With Quote
Old 09-17-2019, 05:32 PM   #10
anotero
Senior Member
anotero's Avatar
Drives: Mk7 GTI S DSG
Quote:
That's interesting, never tried that.
anotero is offline   Reply With Quote
Old 09-19-2019, 10:55 PM   #11
AsymmetricKururin
Junior Member
Turning the wheel seems to work
Thanks to Caleb.Mk7 for the advice about turning the steering wheel fully both ways to eliminate the faults. It seemed to work.
In my case, I still have one databus error on control module 13 (Automatic Distance Regulation) which I believe has something to do with the ACC cruise control safety feature. On my next drive I will try turning on the cruise control and adjusting the distance setting to see if cycling it on/off will eliminate the fault. Then I'll clear the DTC on that module and see if it comes back.
Reply
Tags
battery, databus, module, park/steer, spark
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
