FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Reply
Thread Tools Display Modes
Old 09-05-2019, 09:15 PM   #1
D_o_S
Member
Drives: Golf R Variant
Adding DSG oil through filter housing?
Hello,
is there any issue in adding DSG oil through the top, i.e. after removing the filter?
I'm not too concerned about adding oil this way, but I would like to add a transmission flush... and I don't see it as too realistic to add it from the bottom...
Thanks.
D_o_S is offline   Reply With Quote
Old 09-05-2019, 09:29 PM   #2
mopar22
Senior Member
Drives: 16 GTI SE
Is there a reason you want to flush? It's normally advised against doing that as you can do more harm then good. But yes you can add it through the top no problem
mopar22 is offline   Reply With Quote
Old 09-06-2019, 07:16 AM   #3
George Ab
Senior Member
Drives: GTI MK7, BMW E90
No problem adding from the top. Here is a DIY concerning.
https://www.golfmk7.com/forums/showthread.php?t=32503
George Ab is offline   Reply With Quote
Old 09-08-2019, 09:23 PM   #4
lumberjackzac
Senior Member
Drives: VW GTI '16
Too easy to go in from top. Do it
Sent from my SM-N960U using Tapatalk
__________________
'16 GTI S- DSG LP
JB4|poly engine mounts|catless Rev9 DP|RS3 ignition coils|RS7 sparkplugs|15,20 Spacers|235 Firehawks|AliExpress auto headlights|Thinkware F770|OBD11
lumberjackzac is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
