FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Reply
Thread Tools Display Modes
Old 03-04-2018, 08:18 AM   #1
bluefox280
Junior Member
Drives: 2015 Golf GTI S
Arrow Spark Plug Swap: OEM NGK [06K905601D] to NGK PLFER7A8EG [94833]
Back when I had my Stage 2 MK4 1.8T, I used to change out copper electrode plugs every 10-12K due to cheap, effective maintenance.
I was going to tackle the same on my used MK7 GTI, but due to the different "cup-shaped" terminal type on the spark plug, there wasn't an option to be found.
Wanting to have a baseline for future modifications, I went ahead and swapped out the OEM plugs and saw a lot of variance.
First, some background:
CAR: 2015 Volkswagen Golf GTI (MK7) w/ Performance Pack (purchased with 29,xxx miles)
MODIFICATIONS: none - stock power level
MILEAGE: 32,8xx miles (at time of plug swap)
Some history on the OEM plugs (P/N #06K-905-601-D), which were standard on 9+ different VAG vehicles of the current and previous generation:
* laser welded, dual platinum plug [both center electrode / ground electrode] w/ copper core
* NGK heat range = 7
* specified gap from NGK = 0.031" (0.8mm) - 0.035" (0.9mm)
* specified gap from Volkswagen = 0.032" [unconfirmed]
When I removed the OEM plugs, I measured the gap:
- Cylinder #1 = 0.034"
- Cylinder #2 = 0.032"
- Cylinder #3 = 0.035"
- Cylinder #4 = 0.035"
Visual Inspection - Cylinder #1:
- light gray ash on ground electrode = good air / fuel ratio
- slight peppering of side electrode = first indicator of overheating plug
- slight discoloration of side electrode = second indicator of overhearing plug
- HEAVY pinking of ceramic insulator = indicator of auto-ignition / knocking
Visual Inspection - Cylinder #2:
- moderate pinking of ceramic insulator = indicator of auto-ignition / knocking
Visual Inspection - Cylinder #3:
- moderator peppering on side electrode = first indicator of overheating plug
- Some pinking / browning of ceramic insulator = indicator of auto-ignition / knocking
Visual Inspection - Cylinder #4:
- slight peppering on side electrode = first indicator of overheating plug
- moderate discoloration of side electrode = second indicator of overhearing plug
ONTO THE NEW - while there's been discussions on other OEM variant plugs (like the RS7 plug), or other aftermarket, in my opinion there wasn't a clear winner.
So, I elected to try the OEM equivalent replacement of the NGK PLFER7A8EG [94833].
* bluefox280's gap = 0.028"
Yes, I shorten up the gap on the stock plugs based on experience from my previous MK4 1.8T.
From looking at the original plugs, I'm concerned that if the previous owner did use premium gas 100%, but the plugs are overheating, that a 40K-60K mile service frequency is too long.
Seeing that my GTI only receives premium fuel while in the hands of my ownership, I'm anxious to see how these new plugs react in 15K-20K miles.
Thoughts? Comments? Questions? Curious to see what other DIY owners have to say.
- Erik
bluefox280 is offline   Reply With Quote
Old 03-04-2018, 02:12 PM   #2
Hoon
Senior Member
Hoon's Avatar
Drives: '17 GTI, Sequoia, Turbo Gixxer
You don't have to stay with the cup shaped terminal on top of the plug.
A standard one works fine.
My personal experience, Stage 1 tune at 2k miles and Stage 2 at 5k.
By 20k I had all the signs of tired plugs, rough idle, misfires on cold start, power delivery was not as smooth (hesitations), etc.
Swapped plugs to the cheap Densos IKH24s @.024" and all that crap instantly disappeared.
How much of my plug life was due to a tune and very hard driving, I'll never know, but safe to say 20k was the limit for me.
People also love the RS7s and Brisk Silvers also...I think the Brisk will be my next set.
__________________
Self tuned via Maestro
Turbos change more frequently than signature does
Hoon is offline   Reply With Quote
Old 03-04-2018, 03:02 PM   #3
bluefox280
Junior Member
Seriously? In that case I would have loved to use a much cheaper option plug and change it out more frequently.
- Erik
Old 03-11-2018, 01:09 AM   #4
bluefox280
Junior Member
What other available plugs, with a insulator height of 50.5mm and reach of 26.5mm, can be used?
- Erik
Old 03-11-2018, 07:22 PM   #5
AspektZA
Senior Member
Drives: GTI Mk7 SE DSG
ECS lists these are correct fitment:
https://www.amazon.com/NGK-ILFR7H-La.../dp/B000HDH19I
Though I don't see them listed on NGK's parts finder.
I think this plug is suitable only if you're running colder plugs, as per Stage 2 reqs.
AspektZA is offline   Reply With Quote
Old 03-02-2019, 07:24 PM   #6
lou06483
Senior Member
lou06483's Avatar
Drives: 00 Audi S4 and 15 GTI S
I'm confused----
__________________
Everyone needs a HERO!
lou06483 is offline   Reply With Quote
Old 03-03-2019, 12:07 AM   #7
DiscusInferno
Senior Member
Drives: A modern volkswagen
they the same 7 heat range, not colder. you can tell from the part code
Sent from my SAMSUNG-SM-G930A using Tapatalk
DiscusInferno is offline   Reply With Quote
Old 08-22-2019, 12:43 AM   #8
GeorgeTSI
Senior Member
Drives: Golf TSI Mk7
So what is the actual difference between 06K905601D and PLFER7A8EG ?
GeorgeTSI is online now   Reply With Quote
Old 08-22-2019, 02:47 AM   #9
DiscusInferno
Senior Member
Quote:
The VWAG stamp and lack of ribbing on the insulator.
Old 08-22-2019, 03:24 AM   #10
GeorgeTSI
Senior Member
Quote:
Thanks, does that make any difference in practice ?
Also most photos I've seen of either part have no ribbing.
Old 08-22-2019, 09:01 PM   #11
GeorgeTSI
Senior Member
Also according to some sources, PLFER7A8EG replaces 06K905601B, or even C, but there is no mention of 06K905601D. See here Equivalent Part Numbers:
https://www.amazon.co.uk/NGK-Z%C3%A3...dp/B00U7WB6WC/
On the other hand, these are sold by Volkswagen (branded) and are 2x the price. But the picture shows plug with the... PLFER7A8EG code No ribs anywhere to be seen.
https://www.amazon.co.uk/Volkswagen-...dp/B00KWGNIO2/
What is the deal with these ? Does PLFER7A8EG = 06K905601D ?
Old 08-23-2019, 01:53 AM   #12
GeorgeTSI
Senior Member
Meanwhile on NGK website
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
