FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Golf Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 11-21-2017, 09:18 PM   #392
George Smooth
Senior Member
George Smooth's Avatar
Drives: Golf 7 R
Quote:
Originally Posted by MANU01 View Post
Ordered one!
Do I need the data cable to go between Map 0 and Map1?
As mentioned before the unit ships in map 1. To switch to map 0 you need the cable. What you can also do if you don't intend on getting the cable is put the stock plug back in place on Plug B and leave the JB1 side unplugged. This is the trigger sensor for the JB1 to work so if it see's no boost it will be inactive.
George Smooth is offline   Reply With Quote
Old 01-03-2018, 12:47 PM   #393
quailallstar
Senior Member
Drives: MK7 Golf Variant R-Line
Running 1.8t JB1 Map 6 with below settings for over 6 months now. Has anyone had the feeling of there car not being as fast as originally when initially tuned? Could be me getting used to the "speed", but wondering if maybe my MAF needs to be cleaned?
1500 0
2000 2
2500 3
3000 3.5
3500 4
4000 4.5
4500 5
5000 5
5500 5
6000 4.8
6500 4.5
7000 4.5
__________________
2Ø16 Golf 7 Variant Highline R-Line Pure-Weiß 1,8t FSI « 2Ø11 Golf 6 2,0 6-Gang DPF 2,0 TDI BLUEMOTION Technologies™ Highline Candy-Weiß 5-Türen« Ø8 Golf 5 .:R32 Deep Blau Perleffekt 3,2 VR6 DSG 4-MOTION™ 3-Türen « Ø6 Golf 5 GTI 2,0 FSI DSG Tornadorot 3-Türen « Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen. I Euro-spec OEM Mods
quailallstar is offline   Reply With Quote
Old 01-03-2018, 03:00 PM   #394
TwinDad
Senior Member
Drives: 2016 sportwagen
Quote:
1500 0
2000 2
2500 3
3000 3.5
3500 4
4000 4.5
4500 5
5000 5
5500 5
6000 4.8
6500 4.5
7000 4.5
There is no MAF. Time to upgrade to a JB4. You're just used to it
__________________
2016 GSW- JB4-IS20-CTS TIP-Piggie pipe-K&N filter
TwinDad is offline   Reply With Quote
Old 03-11-2018, 06:05 PM   #395
bimurtud
Junior Member
What is the highest boost on the top end and down low if I don't care about the clutch? Stock 1.8 on 93 octane. Something similar to map 2 on the jb4. I'm at 5.2 on the top and right now and it's just fine but it's not hot out yet either.
bimurtud is offline   Reply With Quote
Old 03-14-2018, 09:57 PM   #396
TwinDad
Senior Member
If you are stock other than is12, about 16-17 peak boost around 3,900-4,300 range. You can turn up the lower setting more, but it will only spool so fast.
__________________
Old 03-16-2018, 08:33 AM   #397
Steenbeek
Member
Drives: 1.8 Tsi 4x4 DSG6
The pros are asked here. Does anybody know how I can adjust throttle sensitivity in absolute setting like the BMW guys can do that in menu 11?
I have one thing that really annoys me and I don't understand why it behaves like that.
I like the absolute setting because of top end power. It holds boost exactly like I want to. But what I don't like is that the car behaves completely stock till 80% pedal input. After 80%, power is there. But it jumpes like it is stung by a bee. I want to feel torque also at 40% input, because I don't always drive binary (0/1). This is what makes me always change back to additive.
I like the additive setting because the car feels much torquier at low to mid pedal input. Boost is added always and I can drive the car much smoother and torquier. But what I don't like here is that the tapering doesn't work as I want to. The boost drops after 5000 much more as I want to and you see that the boost curve doesn't follow the target but the load. And load drops lets say to 4 at the end whereas target dropes to 6. I don't like the feeling of loosing power at top end like the stock car does. This is what makes me change back to absolute. Lol... and the story goes on.
But there must be a way to get the absolute setting behave like additive. I want the power added from the beginning on and not just above 80% input.
Please help me.
__________________
VWR R600 / VWR Turbo Inlet / VWR Turbo Outlet / USP Oil Filter Housing / catch can/ optimized is20 (compressor wheel with extended tip, polished inlet)/ R Downpipe/ egt sensor/ Forge Turbo Blanket / GFB DV+/ TVS ECU+TCU
Steenbeek is offline   Reply With Quote
Old 03-16-2018, 11:57 AM   #398
Steenbeek
Member
Please help me.
Sorry wrong section -> jb4
Gesendet von meinem ZUK Z2121 mit Tapatalk
__________________
Old 04-19-2018, 12:37 AM   #399
cuda2000
Junior Member
Drives: 2017 Golf sportwagen 4 motion and 2010 Audi A4 Qua
I want to install is20 on my 1.8 golf sportwagen 4 motion. I have jb1 currently. Anyway to run is20 with jb1 or do I need to upgrade to jb4?
cuda2000 is offline   Reply With Quote
Old 04-19-2018, 12:57 AM   #400
MeltedSolid
Senior Member
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition, E36 328i
You should really upgrade to a JB4. It's possible to run an IS20 with the JB1, but you will never get close to the potential of the IS20 and you will be comparatively tuning blind.
__________________
2015 TSI Launch Edition | Deep Black | Mk6 GTI 6-spd swap | IS20 swap + APR Stage 1 + JB4 | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe | Mk6 GTI ECS Stage 2 Performance Clutch | BFI Stage 2 engine/transmission mounts
MeltedSolid is online now   Reply With Quote
Old 05-02-2018, 12:04 PM   #401
cuda2000
Junior Member
Best Jb1 map 6 settings for 1.8 sportwagen 4motion?
I know most people upgraded to jb4 but I have first gen jb1 and I love the simplicity of it. I am running map 6 on 93 octane in the USA and it is awesome! No complaints. But is this optimal or too much boost? How do I figure it out? Logging? I have the data cable and a laptop. I started with map1 but these settings on map 6 are more powerful, again, I don't know if I'm hurting anything though?
93 Octane Jb1 map 6
1500 0*
2000 2
2500 3
3000 3.5
3500 4
4000 5
4500 5
5000 5
5500 5
6000 4.8
6500 4.5*
7000 4.5*
Old 05-09-2018, 11:50 PM   #402
toledospeed
Senior Member
toledospeed's Avatar
Drives: 2015 Golf Sport
Quote:
93 Octane Jb1 map 6
1500 0*
2000 2
2500 3
3000 3.5
3500 4
4000 5
4500 5
5000 5
5500 5
6000 4.8
6500 4.5*
7000 4.5*
Are numbers for IS12 or IS20 per you first post? I was pushing about +5.6 PSI on IS12 and JB1 on 93 octane. On JB1, pushing the boost further than +5.3 only has diminishing returns. Only mixing a couple gallons of E85 will remedy this up to a certain extent because the IS12 is well out of it’s efficiency at that point. For the 1.8t and IS20, get the JB4 for proper fueling and AFR. Otherwise, it won’t be worth the upgrade (and is not recommended by BMS). JB4 is just as simple as the JB1 for the most part, except for the AFR tap and OBDII connector. Those are actually really simple too if you are used to working on cars. If you aren’t, then it should be easy to get someone to help.
__________________
| 2015 Golf Sport Edition | Platinum Gray Metallic | 6spd Tiptronic |
| JB4 | IS20 Upgrade | USP Catted DP | Custom Magnaflow catback | DG springs | Enkei TS9 17x8 |
toledospeed is offline   Reply With Quote
Old 05-10-2018, 08:57 AM   #403
Slick99
Senior Member
Drives: 2015 A3 1.8TFSI DSG7 Sedan
Can we run another maps as George has mentioned on Gti threads and here's what George said:
Guys there are a few maps on the JB4 that we have kept silent up till now. Worth it for guys with aggressive settings to test them out first and put up some logs.
Map 3 is a map 2+ map with absolute values. Typically will boost 24psi with a taper to around 20.
Map 5 is a aggressive map to be used with E85 mix or race fuel on full bolt on cars.
Map 8 is the methanol map. The boost additive value is what gets added across the rpm range where 10=1psi, 40 is the starting recommended point for this and the boost will be added in proportion of meth flow. i.e no flow no boost add.
These maps are on all firmware later than 60/1/5
__________________
BMS JB4/TVS stage 2+ TCU flashed/Revo catless DP/modded oem airbox/Revo inlet hose/aFe drop-in filter with snow grate removed/Revo Intercooler/Revo turbo muffler delete/CTS TIP/GFB dv+/034 dog mount/NGK RS7 plugs/OBDeleven
VCDS tweaks visual parking aid, needle sweep & oil temp on DIS
Slick99 is offline   Reply With Quote
Old 05-10-2018, 02:16 PM   #404
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
Not on the JB1.
__________________
ED Moose ECU tune / ED DSG Stage 2 tune / Tomioka IHX475 Turbo / IE IC / MAP cat+res DP / Autotech HPFP / PR 450 LPFP / Uni TIP / EQT TMD and Pipes
Diggs24 is online now   Reply With Quote
Old 05-10-2018, 03:50 PM   #405
Slick99
Senior Member
Quote:
Originally Posted by Diggs24 View Post
Not on the JB1.
Oop I thought this was jb4 thread.
Sent from my HTC 10 using Tapatalk
__________________
Old 05-13-2018, 09:25 PM   #406
cuda2000
Junior Member
Due to increasing gas prices, I'm tempted to go down to 87 octane. Is there a preferred setting on JB1 for 87? Other than turning it off on map zero.
Old 05-14-2018, 05:39 PM   #407
George Smooth
Senior Member
Drives: Golf 7 R
We have done quite a lot of testing recently using the JB4 on 87 and have a idea more or less what will work.
Set boost safety to 3.0 and you should be good for 87.
Old 05-23-2018, 04:45 PM   #408
CanUK
Junior Member
Drives: 2018 GSW 4mo manual
Buy new or used JB1?
I know George is moderating here and a very very helpful resource... no offence intended asking this question: I have limited funds and am considering buying a used JB1 for my MKVII (2018) 4motion sportwagen and wondering if I need to find someone selling the "Group 3" version or if the "Group" is firmware related and can be updated/changed on any "box"?
Also relevant if I'm buying new because my Golf is a bit of a "niche" vehicle here in Canada and I'd want to sell it used one day... would be good to know I have the option of selling to a wider audience when that time comes!
Thanks for any and all assistance.
CanUK is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
