Old 01-27-2018, 08:11 PM   #1
normcaldwell
Drives: 2016 MK7 GTI
RacingLine Golf MK7 Oil Cooler
Just came across this on their site. Looks pretty good.
Probably pricey; but may be a good thing for the track.
https://www.racingline.com/golf7oilcooler
2016 MK7 GTI, Carbon Steel Metallic, Direct Shift Gearbox, Performance Package, Lighting Package, Dynamic Chassis Control.
normcaldwell is offline   Reply With Quote
Old 01-27-2018, 08:19 PM   #2
Sandman GTI's Avatar
Easy fit in design.
I assume the oil filter now switched to a screw on canister?
Would it be a cannon part?
Sandman
My Build Thread: http://www.golfmk7.com/forums/showthread.php?t=6100
Old 01-27-2018, 08:33 PM   #3
normcaldwell
Originally Posted by Sandman GTI View Post
Easy fit in design.
I don't know for sure; but I would expect that the canister would still work with the stock oil filter stick and slide-on filter.
I wish the site had an installation manual to download.
Old 01-27-2018, 08:41 PM   #4
But what’s it cost?
Old 01-27-2018, 09:35 PM   #5
I will bid $250.
A guess as I have not looked up other units.
If wrapped in CF then $750.
Sandman
Old 01-27-2018, 09:39 PM   #6
The new filter part looks like it would have a small center threaded hole to screw on. Wishing I could reuse my CTS finned oil filter cover but I think not.
Sandman
Old 01-28-2018, 12:47 AM   #7
TecklenburgVW
TecklenburgVW's Avatar
Drives: 2015 Golf R w/ Tech Tornado Red
Sub'd, will read up on this later tonight. I suspect they plan to release a similar system for the DSG too.
Sent from my SM-G920V using Tapatalk
TecklenburgVW is offline   Reply With Quote
Old 01-28-2018, 06:48 AM   #8
tripleS
tripleS's Avatar
Drives: 15 GTI S 6MT/LP/PP (Sport prototype ;)
I'm guessing it'll end up being around $399 or thereabouts. Most of the VWR parts are nice, but can be pricey (see the AOS). But let's thank the lord it won't be made of carbon fiber and end up being around $600.
How high are folks seeing oil temps go on track with the typical stage2 or IS38? I've seen mid-250s completely stock, not sure if much higher would be cause for alarm.
2015 GTI S 6MT/PP/LP | BFI catch can | Bilstein B8s + Neuspeed Sports | ST RSB | Pagid RSL29(f) | TT RS air guides | Neuspeed RSe10 18x8.5 gunmetal
tripleS is offline   Reply With Quote
Old 01-28-2018, 08:29 AM   #9
TecklenburgVW
Stock power in July at Sebring - oil temps can reach 270+.
Old 01-28-2018, 02:37 PM   #10
jmason
Drives: 2015 GTI S 4 Door 6MT Night Blue Metallic with LP
I wonder if you can snake an extractor tube down the hoses to suck out oil during an oil change. But then, how do you fill it? The oil in the hoses and cooler doesn't drain back into the sump. I would guess there is at least 1/2 qt of oil in the hoses and cooler.
Around $400 would be nice, but I suspect it will be higher.
3M Crystalline 50% tint | P3 Cars VIDI Display | Bilstein PSS10 | Conti DWS06 235/40 | Cross-Drilled and Slotted rear Rotors | Short Shift Kit | Tyrolsport Deadset | BFI Catch Can | Neuspeed REs12 18 x 8 Bronze | Eurocode Adj F & R SBs | SuperPro End Links | BFI Weighted Shift Knob | Brembo 330mm BBK | Solid Shifter Bushings | SuperPro Alloy 0006K LCA | CSS Swivels | TT Front Bearings | Wavetrac LSD | RSR Clutch Kit
jmason is offline   Reply With Quote
Old 01-28-2018, 05:58 PM   #11
normcaldwell
I'd be interested as well in a DSG cooling product designed for the MK7 GTI.
Doesn't the R already have an auxiliary DSG oil cooler?
Yeah, it might be that the 1/2 quart, along with some oil at the bottom of the filter canister, will be mixed in with the fresh oil. I change my engine oil rather frequently, so I think it would be o.k.
Old 02-09-2018, 10:13 PM   #12
carchrism5
carchrism5's Avatar
Drives: 17 GTI Sport
That looks very nice, if below $400 it would be hard to say now, but I think that is a very very slim probability.
carchrism5 is offline   Reply With Quote
Old 02-10-2018, 12:26 AM   #13
jmason
My guess is closer to $700. I hope Iím wrong.
Old 02-10-2018, 01:41 AM   #14
teemmy
teemmy's Avatar
Drives: 2015 GTI
Hrm... knowing VWR it will be pricey. I wouldn't be surprised if it's $500-600
2015 White GTI S 6MT LP
EQ protuned IS38 / RSR / Wavetrac
teemmy is offline   Reply With Quote
Old 02-10-2018, 03:30 PM   #15
RadioFlyer
RadioFlyer's Avatar
Drives: GSX-Rs ~ '05 GLS TDI ~ '16 GTI SE PP DCC LP MT
In lieu of VWR import rumors, maybe you already found this set up....looks like a bad dream to install.
Name:  iABED Industries oil cooler.jpg
Performance numbers read very good tho.
RadioFlyer is offline   Reply With Quote
Old 02-10-2018, 07:58 PM   #16
normcaldwell
Their pic shows it installed in what looks like an MK6, and the ad does not specify which EA888 version.
Agreed on the bad dream observation . . . lol
Old 02-10-2018, 10:14 PM   #17
TecklenburgVW
That is for the EA888 generation 3.
Aka, EA888.3
