Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Regional Forums > Great Lakes
Old 03-24-2017, 11:57 AM   #1463
SuperDuper
Drives: 2016 GTI
Originally Posted by snobrdrdan View Post
With a $10 terminal tool, it's pretty simple if you watch the DIY videos
Routing the harness (under the trim) is the only tricky part
Thanks, yeah I watched a video. I'm more nervous about the part when you get to the glove box and start messing with the terminals.
SuperDuper is offline   Reply With Quote
Old 03-24-2017, 02:19 PM   #1464
tkoo
Drives: MK7 GTI
Originally Posted by Merkeyterkey View Post
What kind of front plate holder did that guy have?
It's a Platypus. Kind of a pain if you have park distance sensors... gotta line it up just right.
Don't mind the salt
tkoo is offline   Reply With Quote
Old 03-24-2017, 09:28 PM   #1465
Jay745
Moderator
Jay745's Avatar
Drives: K04 mk6 gti, mk5 rabbit
I'm doing a suspension install this sunday for another mk7 local. I wonder if the strut mounts design was improved over the mk6. A lot of the mk5/mk6 strut mounts get stripped and you have to cut them out. We'll find out!
Mk5 Rabbit (Daily) Build Thread
MK6 K04 GTI Build Thread
Hit me up for Vagcom or DSG Service in Chicago (Cheaper than dealer/indie)
Jay745 is offline   Reply With Quote
Old 03-25-2017, 04:34 AM   #1466
DanJoy
Drives: MK7 GTI Autobahn PP
When removing the top nut on the strut? I had no issues, but the car also had about 1000 miles on it.
DanJoy is offline   Reply With Quote
Old 03-25-2017, 07:50 AM   #1467
snobrdrdan
snobrdrdan's Avatar
Drives: a VW
Send a message via AIM to snobrdrdan
With the battery unhooked, there won't be any issues and it's stupid easy.
Get the terminal tool & it's just swapping a couple wires & plugging the harness in.
'17 Passat VR6
snobrdrdan is offline   Reply With Quote
Old 03-25-2017, 07:53 AM   #1468
snobrdrdan
snobrdrdan's Avatar
Drives: a VW
The mounts are different shaped (they're angled), but still of the same design.
They actually use the same mount bolts still, lol. But on a newer MK7, shouldn't be an issue. I always put anti-seize on them when I reinstall the bolts along with the swaybar endlink threads, for the future.
And then they added a rubber isolator to the base of the strut (seat)
The strut bearing only installs one way (there is a notch on the mount to line it up with)....so make sure that stays the same.
Outside of that....just use the 2x4 method to remove the strut and it's like a MK5/MK6 still
The rears are a little trickier though, since now 3 bolts go thru each LCA....instead of just the 1 on the MK5/MK6
'17 Passat VR6
Old 03-25-2017, 03:06 PM   #1469
DanJoy
that fragile light level sensor connected to the drivers side LCA always makes me nervous when working on that corner. It's so flimsy.
Old 03-25-2017, 06:00 PM   #1470
Jay745
Moderator
Jay745's Avatar
Heh I'm not worried about it. Have done a ton of suspension jobs for locals over the years. Sometimes the nutsert just strips out and spins inside of the strut mount. I dont expect to see any issue from a newer mk7.
Old 03-26-2017, 09:14 PM   #1471
DanJoy
Been seeing more mk7's lately. Just saw a white 4 door lowered with aftermarket wheels and "urban joke" tail light coding on 34 in Oswego.
Old 03-26-2017, 10:59 PM   #1472
Jay745
Moderator
Jay745's Avatar
Suspension install on the locals mk7 gti went really smooth. Although I have to say I'm not endorsing ST coilovers. They have only one retainer which makes adjusting ride height in the rear take a long time. Ended up taking the spring down again in order to adjust it.
Old 03-26-2017, 11:10 PM   #1473
cbaumy34's Avatar
Looks good!
Sent from my SAMSUNG-SM-G930A using Tapatalk
cbaumy34 is offline   Reply With Quote
Old 03-27-2017, 02:43 AM   #1474
DanJoy
Car is from Elgin I believe.
Old 03-27-2017, 02:44 AM   #1475
Jay745
Moderator
Jay745's Avatar
Yep. Matt is the owner from the elgin area
Old 03-27-2017, 05:57 AM   #1476
DanJoy
Think I remember that from a post on the MK7 FB page. Seems to be a lot of MK7's around here but not much of an enthusiast community like there was with the MK6.
Old 03-27-2017, 02:54 PM   #1477
Jay745
Moderator
Jay745's Avatar
Should come to our meets sometime, we meet every thursday evening. Go like our fb page for more info, last year Deutschland Raketen won an award at windy city dub fest for largest club presence.
Come hang out some time
https://www.facebook.com/Deutschland...5276928570263/
Old 03-27-2017, 06:34 PM   #1478
DanJoy
Thanks, liked. I work evenings but may check it out sometime.
Old 03-28-2017, 08:13 AM   #1479
snobrdrdan
snobrdrdan's Avatar
Drives: a VW
Actually after working on a MK7 GTI this weekend....the strut mount bolts are different (they have a washer on the bolt)
ST coilovers have the same perches as the MK5/MK6/etc....Konis, KW's, Raceland, new FK's....they're all like that
You can't adjust them on the car....it's easier to just drop the LCA and adjust the perch off the car
ALTHOUGH, it's a pain in the ass on the MK7 since you have the extra 2 bolts going thru it versus a MK6
Just curious, how long did it take you?
'17 Passat VR6
#assman, #mudrunz, mk6 > *, mk7 = teh slow, mk7r is the best
