Old 09-01-2018, 04:20 AM   #1
koalb
Drives: 2016 GTI SE w/PP+LP
Bumper Damage Not so Bad or Really Bad?
Had a pheasant or some other kind of large game bird land right in front of my car as I was moving down the highway (dumb bird!). Once I pulled over, noticed that the overall damage didn't seem too bad, but a lot of trim pieces were pushed out of position, fog lights are pushed back, center grill came out of it's tabs.
Wonder if a more experienced eye could tell if this is mostly about taking it apart and putting everything in the right position – or if there might be enough broken tabs, etc that replacement parts might be required.
I also just noticed when I looked at these pictures that there's a crack on the inside lip of the bumper. Would trim pieces cover this up?
And yes, I'm a little bit OCD. Have been babying this car for the past two years and really, really bummed out by this freak accident.
https://drive.google.com/file/d/1SNV...ew?usp=sharing
https://drive.google.com/file/d/1fmc...ew?usp=sharing
https://drive.google.com/file/d/1rX-...ew?usp=sharing
https://drive.google.com/file/d/1gl5...ew?usp=sharing
https://drive.google.com/file/d/1mT0...ew?usp=sharing
koalb is offline   Reply With Quote
Old 09-01-2018, 04:44 PM   #2
Jose_Gti
Jose_Gti's Avatar
Drives: Golf GTI MK7
To me it doesn’t look that bad, I would try to put it all together. There’s no way to know for sure if more tabs are going to be broken.
Be extra careful with the crack in the lip, that may need to be fixed/glued...
MT APR stage II APR Down Pipe. APR Intake. RS7 plugs/RS3 Coil Packs. 034 Dogbone. APR short shifter full system. ECS Clutch Bleeder Block. Billy Boat Resonator. TTRS Clutch kit. UBQ unibrace and Neuspeed sway bar. APR Intercooler + Apr boost hoses, apr turbo inlet pipe.
235/40ZR-18 Michelin Pilot Sport A/S3
Jose_Gti is offline   Reply With Quote
Old 09-01-2018, 04:52 PM   #3
pitterchi
Drives: 2017 GTI Sport DSG
Looks bad to me. I might be OCD too.
It would bother me...
pitterchi is offline   Reply With Quote
Old 09-02-2018, 10:43 PM   #4
tnthlttr
Drives: 2016 VW Golf TSI
fixed.
tnthlttr is offline   Reply With Quote
Old 09-03-2018, 03:23 AM   #5
Jose_Gti
Jose_Gti's Avatar
LMAO!
Old 09-25-2018, 01:49 PM   #6
The Fed's Avatar
Drives: 2016 Golf R
Originally Posted by Jose_Gti View Post
LMAO!
+1
Old 10-30-2018, 03:22 AM   #7
koalb
OK, so finally got around to pulling the bumper cover off. Seems like with a few replacement parts, and patching some cracks, it might be hard to spot the damage. (And save me the price of a trip to the auto body shop.)
You're seeing the bulk of the damage below. A couple cracked pieces and a nice long crack in the bumper cover along the RH fog light trim piece tabs.
Would welcome any expert advice pertaining to:
1. Recommended products for repairing cracks (they'll all be hidden behind trim. Have had good luck with 3M products – was looking at 3M bumper repair kit/epoxy). Any other suggestions?
2. What's the best tool to remove all these trim pieces without damaging the tabs? I've got some interior trim removal tools, assuming those would work?
Old 10-30-2018, 03:54 AM   #8
swoope
swoope's Avatar
Drives: 17 gti sport / 04 rx8 track car
i would use jb weld.
and screwdriver.
beers
swoope is offline   Reply With Quote
Old 10-30-2018, 04:12 AM   #9
koalb
and screwdriver.
beers
JB Weld over 3M?
Curious why?
Old 10-30-2018, 04:41 AM   #10
swoope
swoope's Avatar
i just use it a lot.
no experience with 3m.
beers
Old 11-10-2018, 12:21 AM   #11
The Fed's Avatar
Drives: 2016 Golf R
That fender piece can't be that expensive. I'd replace it.
