Old 07-26-2018, 04:27 AM   #1
Jed
Drives: 2017 VW GTI SE W/Lighting Package, '76 BMW 2002
Seat Belt sensor off passenger seat after seat swap
Hey all!
Just swapped my seats for some clark plaids.
I am getting the seat belt light and chimes even when no one is sitting in the passenger seat, and I have nothing resting in the passenger seat.
So far I have tried sitting in it myself, buckling up, and un buckling hoping that would reset it. And I unplugged and plugged the seat back in while the car was off. Still getting the light.
Thanks.
Jed is offline   Reply With Quote
Old 07-26-2018, 04:29 AM   #2
Did you swap seat modules as well during the swap? From what I understand they must also be swapped since the leather has different boxes/coding than plaid
Old 07-26-2018, 04:39 AM   #3
Jed
We did not. I just read that too.
But I also read that even after swapping boxes errors were still being thrown and the only fix was going to a dealer to get the codes fixed.
Old 07-26-2018, 04:55 AM   #4
The box is coded to the seats so no further work should be necessary after the boxes have been swapped
Old 07-26-2018, 05:15 PM   #5
Jed
What if the boxes can't be swapped? Would a dealer be able to fix it?
Old 08-27-2018, 02:43 PM   #6
The Fed's Avatar
Drives: 2016 Golf R
Why not?
