Old 07-16-2018, 04:10 AM   #1
Bäsemödel
Drives: 15 Golf TSi
UPDATE - 1.8T EPC/CEL no boost...
My obd eleven wont connect To my phone right now for some dumb reason (of course at the moment I truly need it) so I can’t get any more detail than what they said at autozone until I go to the shop tomorrow... but basically, I think it’s a wastegate actuator issue... the code was p334a and, based upon my reading, the a suggests it’s an electrical not a mechanical issue... Something is preventing boost from building because I just hear it blow off instantly after building...
Crossing my fingers it’s something simple. First issue I’ve had w this car in 80k...
Build
Helix UUs//deAuto LEDs//Blacked Roof//Maxton Lip//GTI Skirts//RS7 Plugs//IS20//aFe Dry Filter//JB4//OEM Hatch Spoiler//18” Peelers//Magnaflow Catback w/ center exit//CTS Dogbone//GTI PP RSB//Indy 500s//Koni Special Active Shocks//VWR Springs//HELIX Sub//OBD11//OEM Add Ons - adding fogs/footwells is possible!
Bäsemödel is offline   Reply With Quote
Old 07-16-2018, 05:26 PM   #2
Sparky589
Sparky589's Avatar
Drives: Mk7 Golf TSi
Is all the piping still in place? Had one of my charge pipes pop off after I went is20, so it may be worth checking.
2016 TSI | Platinum Gray | 6-spd slush | APR IS20 w/DP | APR Downpipe | AWE Track Exhaust | Vibrant 17930 | VWR R600 | BFI Stage 2 Mount Kit | BC BR Coilovers | Konig Ampliform | 034 Front + Rear Sway Bar | Michelin P4s
Sparky589 is offline   Reply With Quote
Old 07-18-2018, 09:42 PM   #3
Bäsemödel
Drives: 15 Golf TSi
just got of the phone with the shop... the internally actuated wastegate has failed... specifically the actuator itself... It cant be serviced (at least by the shop I have the car at) and the turbo will need to be replaced...
any thoughts?
Build
Old 07-18-2018, 09:51 PM   #4
Sparky589
Sparky589's Avatar
I'd say look into gpop, they can do turbo rebuilds for a decent price so chances are they may be able to fix it up. Other than that the classifieds are flush with is20's, so if you want to significantly up the power that's always the option.
It also helps that while somewhat challenging, swapping the turbo is easily something you can do yourself.
Old 07-18-2018, 10:54 PM   #5
MeltedSolid
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition
If you can find a wastegate separate from a turbo then it can easily be serviced. You'll need to do the wastegate calibration, but it's a hell of a lot easier than a turbo replacement.
In fact, I do happen to have an IS12 wastegate sitting around on my old IS12...
Or, you could always go IS20.
2015 TSI Launch Edition | Deep Black | 6-spd manual swap | IS20 swap + APR Stage 1 + JB4 | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe | Mk6 GTI ECS Stage 2 Performance Clutch | BFI Stage 2 engine/transmission mounts
MeltedSolid is offline   Reply With Quote
Old 07-19-2018, 12:09 AM   #6
Bäsemödel
Drives: 15 Golf TSi
I do want to go IS20... ultimately...
I guess whats odd to me is if you have an IS12 wastegate sitting around, why cant the shop replace it... is it not the kind of part you can buy seperate usually?
Also, the classifieds are devoid of IS20s the instant I need one... great
Build
Old 07-19-2018, 12:10 AM   #7
Bäsemödel
Drives: 15 Golf TSi
I just need the space and time... and while I feel like I can do most mechanical work on this car, I feel like a turbo is certainly something Id like to do with someone who is experienced ...
Build
Old 07-19-2018, 12:45 AM   #8
Because the shop doesn't know how to set one. They aren't sold separately so they just go buy what some shop manual says.
Old 07-19-2018, 04:03 AM   #9
Bäsemödel
Drives: 15 Golf TSi
Lovely... well I’m gonna keep doing some reswatch...
Thanks for your help all!
Build
Old 07-19-2018, 04:14 AM   #10
Do the turbo swap to is20.
Old 07-23-2018, 02:57 AM   #11
Bäsemödel
Drives: 15 Golf TSi
Well the IS20 has been purchased... being installed this weekend
Build
Old 09-17-2018, 06:17 PM   #12
xGreg
Drives: 2015 Golf TSI 1.8T
The dealer just called me telling me I need a new turbo. The EPC light came on a few days ago. Luckily i'm at 37k so the power train warranty covers it.
xGreg is offline   Reply With Quote
Old 10-29-2018, 06:53 PM   #13
mk7_gsw
Drives: 2015 Golf Sportwagen TSi S
Dammit now you got me worried as im at 85k miles and a 2015, hopefully mine doesnt die anytime soon, although i have factory warranty till 10yr/150k miles. Thanks California and the PZEV rules
mk7_gsw is offline   Reply With Quote
