Old 02-01-2018, 11:51 PM   #69
Sheikyurbouti
Drives: '15 GTI 6MT 2dr Tornado Red
I found that the airbox mod is worth doing: I taped up the back-side of the inlet with gaff tape. If you peer down the inlet, it's significantly restricted and from my eyeball I determined it's smaller than the TB inlet tube. I opened up the drivers side with an oscillator tool. I also removed the leaf guard, but it really doesn't appear restrictive. I have heard someone mention the term "turbulence" in reference to the leaf guard, but I doubt the turbulence reduced is enough to notice. When you consider the temperature increase developed by the compressor at the intake manifold, perhaps the tape does no good either.
But wait a minute: There is a very noticeable improvement in engine happiness! My right foot is happier! I grin more!
Your happiness may vary.
APR turbo muffler delete, soundaktor disco, BFI insert, Neuspeed PM. 37mpg!!!
Sheikyurbouti is offline   Reply With Quote
Old 02-02-2018, 07:13 AM   #70
Slick99
Drives: 2015 A3 1.8TFSI DSG7 Sedan
U can buy the euro air trim plate to make it look neat n oem. I got it from
http://www.oemvwshop.com/5Q0129849-a...plate-p953879/
Sent from my HTC 10 using Tapatalk
BMS JB4/Revo catless DP/modded oem airbox/Revo inlet hose/aFe drop-in filter with snow grate removed/Revo Intercooler/Revo turbo muffler delete/CTS TIP/GFB dv+/034 dog mount/NGK RS7 plugs/OBDeleven
VCDS tweaks visual parking aid, needle sweep & oil temp on DIS
Slick99 is offline   Reply With Quote
Old 02-19-2018, 09:12 AM   #71
bigdave79
Drives: VW GTI Mk7
Looks like the 2018 GTIs have vertical slots cut out on either side of the grille. If you're going to cut open the blocked holes on the air intake duct, wouldn't you also need those vertical slots to help the air get up in there?
I'm sure a replacement grille just for these slots would be prohibitively expensive but there are some intake manufacturers that provide a template to cut a neat looking scoop into the driver's side section of the grille. Like this one:
I'm sure it wouldn't be too hard to 3D print something like this...
EDIT: just found this thread:
D.I.Y. - Intake Air Scoop/Eventuri Piece https://r.tapatalk.com/shareLink?url...3&share_type=t
Sent from my SM-G950U1 using Tapatalk
bigdave79 is offline   Reply With Quote
Old 02-19-2018, 03:26 PM   #72
Mathuemc
Mathuemc's Avatar
Drives: Pure White MK7
Interesting. I wonder if the '18s have the duct open on both sides then? I'm also curious what the cost of that piece of the grill would be.
Sent from my Pixel 2 using Tapatalk
Mathuemc is offline   Reply With Quote
Old 02-19-2018, 04:44 PM   #73
bigdave79
Drives: VW GTI Mk7
I think the forum member breaking badly confirmed that the holes for the air duct are still blocked on the '18s despite the changes to the grille.
Old 02-19-2018, 09:30 PM   #74
Mathuemc
Mathuemc's Avatar
That would be even more interesting.
Old 06-17-2018, 04:45 AM   #75
jackalope
Drives: Golf
Originally Posted by breaking badly View Post
There's a suitable OE part to block the factory hole on rear:
5Q0 129 849
Why is that part sold in other countries? Why doesn't the American Golf have that piece?
jackalope is offline   Reply With Quote
Old 07-01-2018, 04:46 AM   #76
Christophunkk
Drives: Mk7 GTI 6MT
I think this is it at about $210.00.
https://vwpartsdepartment.com/parts/...iagram=9282017
I'm wondering if it would fit the previous MK7 models.
2016 GTI Autobahn | 6-Speed Manual | Deep Black Pearl
Other Cars: 2010 Toyota Tundra Crewmax | 2013 Mercedez-Benz GLK350
Christophunkk is offline   Reply With Quote
Old 07-13-2018, 09:12 PM   #77
Ital
Drives: 2016 Golf GTI
does anyone just sale the front with Dual inlet open that works with the stock intake?
Just like the Racingline R600 Cold Air Intake?
APR Stage II | South Bend Stage 3 endurance | Eibach Pro Springs
Ital is offline   Reply With Quote
Old 07-13-2018, 09:26 PM   #78
Clem604
Drives: 2018 GTI
You don't need to buy one. Just get a Dremel and drill out the inlet on your stock intake. If you really want to buy one ECS sells a carbon fiber one
MK7.5 GTI 6MT
JB1/Majesty IC/034 Upper+Lower Dogbone Mount/034 Eng+Trans Mounts/APR Pendulum Mount/034 Intake/APR TIP/Forge TMD/Remus Axleback/Neuspeed Short Shifter/42 DD Shifter Bushings/ECS Clutch Bleeder/ECS Clutch Line/WCT Pedal Spacer/DG Springs/EuroCode F/R Chassis Bars/Unibrace UBQ/H&R 24mm RSB/EBC Redstuff Pads/18x8 OZ Alleggerita
Clem604 is offline   Reply With Quote
Old 07-13-2018, 09:44 PM   #79
Ital
I dont get why the OEM is blocked off? what is the logic?
Old 07-13-2018, 10:24 PM   #80
Twist
Twist's Avatar
Drives: 2015 GTI SE 6MT - Unicorn Build Date :)
I've done a lot of experimental stuff with this and viewing under the hood of the new mk7.5s, I literally think they just made a mistake. I think they realized that it was blocked and did some testing and saw that a vacuum could pull air from the other side but that obviously this is not ideal..
They probably pitched it as "more weather proof." And we're so far gone the rabbit hole they just decided to leave it.
PM for Aluminum Heat Res. Air Scoops
PM for Obd11 Long Coding Help
Twist is offline   Reply With Quote
Old 07-19-2018, 12:05 PM   #81
llibgrebnek
That piece is not used on US spec VW to avoid a snow packed inlet, which is one of the myriad development tests the vehicles undergo. It snaps in/out which is too much to ask the lowest common denominator US driver to perform in the event of a packed inlet.
llibgrebnek is offline   Reply With Quote
Old 07-19-2018, 12:38 PM   #82
Faceman
Drives: 2017 GSW S 4Mo
There is provision for a screw to secure it in place, too.
Faceman is offline   Reply With Quote
Old 07-19-2018, 09:42 PM   #83
I did a nice big how to guide..to fit the rear left blanking piece...& to open up & fit the front right water baffle..all from the GTE (hybrid)....
https://www.golfmk7.com/forums/showthread.php?t=41797
My Build:- Click Here
Old 07-25-2018, 05:02 PM   #84
jackalope
Drives: Golf
That makes sense!
Old 08-03-2018, 06:15 AM   #85
Garwoodproject
Drives: 2016 GOLF S
Read about this mod, cutting open drivers side vents, liked what I read so I did mine today
Garwoodproject is offline   Reply With Quote
