Old 01-03-2017, 11:04 PM   #35
Ton
Drives: Golf
The shocks and struts are also good enough on the stock car that VW even allows the use of VWR lowering springs without shock/strut upgrade.
Ton is offline   Reply With Quote
Old 01-04-2017, 02:18 AM   #36
TwinDad
Drives: 2016 sportwagen
Originally Posted by 1.8wolfie View Post
Lol, I liked your rant. I agree wholeheartly. I've been through a couple different car groups (pontiac firebirds, trucks, bmw, mercedes). They all have the same thing going on like your saying.
I was just going on the sense that if you were looking for gti power, and going to spend the same amount to get there as you saved, then it's not worth it. But If you can keep it still under GTI price, and your happy with the results, then more power to you.
Just the JB4 or stage 1 will put you at stock gti level. So it doesn't take too much
Old 01-04-2017, 02:23 AM   #37
odessa.filez
odessa.filez's Avatar
Drives: 2016 GSW 1.8T S
As much as I like the GTI, the GSW has more versatility. Perfect sleeper for modding, basically the same bones as the GTI. Has a nicer ride for some of us.
Sent from my Nexus 6 using Tapatalk
JB4 - Vorshlag camber plates - Audi TTS LCA - PP rear sway - Koni Yellows - GTI springs - bump springs, spring rubbers and other do-dads - 205/50/r15 re-71r
- ESC OFF
odessa.filez is offline   Reply With Quote
Old 01-04-2017, 02:14 PM   #38
Slick99
Drives: 2015 A3 1.8TFSI DSG7 Sedan
Whats the stock Gti timing to reach 0-124mph (200kph)? I m doing around 22-23sec to reach 200kph on my jb1 map1 (4.2psi) A3 1.8T and i think m still slower than stock gti.
BMS JB4/Revo catless DP/modded oem airbox/Revo inlet hose/aFe drop-in filter with snow grate removed/Revo Intercooler/Revo turbo muffler delete/CTS TIP/GFB dv+/034 dog mount/NGK RS7 plugs/OBDeleven
VCDS tweaks visual parking aid, needle sweep & oil temp on DIS
Slick99 is offline   Reply With Quote
Old 01-04-2017, 03:05 PM   #39
TwinDad
Based on APR that is in line with their stage 1 car, if not quicker. They say 23.6 for 0-125 mph. They say that car will hit 0-100mph in 13.4 vs the stock gti at 14.9. So yes you are then quicker than a gti and you are only adding 4.2. Someone in the colder climate can add 5.3 no problem and even more on the JB4
Old 01-04-2017, 04:32 PM   #40
Slick99
I want to increase the boost but here i get 95 RON (89-90 octane) which is not supporting but i hope once i get jb4 i can increase to 4.4-4.6psi
Sent from my HTC 10
Old 01-04-2017, 05:25 PM   #41
TwinDad
Sent from my HTC 10
Have you logged at all to see what your actual peak boost is? I'm curious to see what it is in the hot weather. I'm at freezing and near freezing temperatures right now. The ecu will only give out about 8psi stock. If yours is requesting more, you may be hitting more than someone at 5.3 in a colder climate
Old 01-05-2017, 07:08 AM   #42
Slick99
My last logged was 6 months back in July wen i was dyno'ing my car, it was showing 10-11psi on map 0 and 14-15psi on map 1 4.0psi and temperature was around 37c
Sent from my HTC 10
Old 01-05-2017, 02:26 PM   #43
TwinDad
Sent from my HTC 10
The computer definitely reacts to the temperatures. I couldn't get more than 11psi on map 1 or map 6 set to 5.6. I'm now doing the target on the JB4 and hitting up to 15.8. Pulled it back a little bit because of the timing. 15.2 now and it looks good and pulls strong. The downpipe is a tempting next mod
Old 01-05-2017, 03:58 PM   #44
whitewagen
Drives: Sportwagen
Would you mind posting your Map 6 settings?
whitewagen is offline   Reply With Quote
Old 01-05-2017, 09:04 PM   #45
Slick99
I was pulling timing when i set map 6 set to 4.4 also my car got heat soaked, downpipe is real power will give another 10-15whp.
Sent from my HTC 10
Old 01-05-2017, 10:41 PM   #46
TwinDad
I will post them up a little later. I have them written down in my car. I still have to remove a little bit around 4500-5000. It didn't hit the target and pulled a couple of degrees on 2 cylinders. FYI. I tried royal purple octane booster. It didn't do anything to reduce the timing corrections
Old 01-05-2017, 10:42 PM   #47
TwinDad
Sent from my HTC 10
Going to keep it on the short list for sure. It gets addicting
Old 01-06-2017, 12:55 AM   #48
TwinDad
Current map 6 settings. Any corrections were 1 or less. It's at 32 degrees and it wasn't hitting the target all the way through. Ecu was only requesting 8.6 max to 4.2 up top. i was hitting 15.2 down to 11.2 up top in third gear pull. When it was in the 50's, I was carrying over 15psi all the way to 5500.
1500 - 10.2
2000 - 11.5
2500 - 13.1
3000 - 14.1
3500 - 15.5
4000 - 16.0
4500 - 15.5
5000 - 15.0
5500 - 15.0
6000 - 14.5
6500 - 13.8
7000 - 13.1
Old 01-06-2017, 02:01 AM   #49
4MotionWagen
4MotionWagen's Avatar
Drives: 2017 GSW S 4Motion Platinum Gray Metallic
1500 - 10.2
2000 - 11.5
2500 - 13.1
3000 - 14.1
3500 - 15.5
4000 - 16.0
4500 - 15.5
5000 - 15.0
5500 - 15.0
6000 - 14.5
6500 - 13.8
7000 - 13.1
Can you send me your map2 log in a PM or PM me for email address. I am having problems and am currently working with george to fix the issues but I would like to see what a good clean log looks like. lol. It would help me with what I am seeing.
4MotionWagen is offline   Reply With Quote
Old 01-06-2017, 01:15 PM   #50
TwinDad
I sent you a PM with my email. What issues are you having?
Old 01-06-2017, 02:54 PM   #51
4MotionWagen
PM sent, Thank you
