FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Golf Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 06-23-2018, 06:41 PM   #1
pglendinning
Member
Drives: Golf Sportwagen
Diverter valve errors, APR tune
Yesterday my Golf 1.8t threw up an EPC warning light. I took the car to the dealer and they ran a scan, which showed an intermittent diverter valve error. They cleared the code and sent me on my way. Almost immediately it happened again, and this time the car went into limp mode. I limped back to the dealer and left it with them for more diagnosis.
Two questions: 1) how likely is it that the dealer will blame the error on the APR tune? and 2) how would you suggest I argue against that assignation of blame?
Thanks in advance.
pglendinning is offline   Reply With Quote
Old 06-23-2018, 09:40 PM   #2
MeltedSolid
Senior Member
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition
It depends a lot on the dealer. There's a chance they will completely blow you off, in which case the diverter valve is not too expensive and super easy to replace. Obviously an APR tune won't break a diverter valve, but some dealerships are super weary and won't even touch modded cars. At my local dealership I would expect them to potentially even ignore the fact that I don't even have a stock turbo if I was trying to fix the problem you are having, they are really good.
If they do send it back your way I wouldn't bother fighting them on such an easy fix, you might even be able to find a used diverter valve for very cheap here on the forums. Then it's literally right on the very top of your engine bay, 3 allen bolts and you're done.
EDIT: Worst case scenario: https://www.shopdap.com/06h-145-710-c.html
__________________
2015 TSI Launch Edition | Deep Black | 6-spd manual swap | IS20 swap + APR Stage 1 + JB4 | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe | Mk6 GTI ECS Stage 2 Performance Clutch | BFI Stage 2 engine/transmission mounts
MeltedSolid is offline   Reply With Quote
Old 06-24-2018, 03:30 AM   #3
pglendinning
Member
Thanks for this reply. I think if it come to this I will probably replace the DV in their parking lot out of principle.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
