FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > GTI Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 09-15-2018, 06:25 PM   #1
KingKhan
Member
Drives: GTI
OEM Spark Plug Replacment Gap
I am seeing conflicting information on information regarding spark plugs.
I am completely stock and just looking to replace the original plugs according to the maintenance schedule.
My car is currently at 60k km I purchased the "Actual OEM" plugs quoted by rock auto which were NGK. They are gapped at 0.032", but i also see that the OEM plugs on DAP are Bosch and gapped at 0.028".
Which is correct?
KingKhan is offline   Reply With Quote
Old 09-15-2018, 06:47 PM   #2
SugarMouth
Senior Member
SugarMouth's Avatar
Drives: 2016 GTI Autobahn DSG PP LP
.028 which is what they likely will be close to out of the box.
__________________
2016 GTI Autobahn DSG | FBO | Littco L450
SugarMouth is offline   Reply With Quote
Old 09-16-2018, 02:51 AM   #3
0bLiViOuS
Senior Member
Drives: 2016 GTI SE PP 6MT
I personally recommend running the largest gap you can without getting blowout, but I do think .028" is the stock gap.
__________________
2016 GTI SE 6MT
IS38, ED Maestro, CTS DP, IE Intercooler, IE Closed Air Intake, CTS TIP, Neuspeed Charge Pipe/TMD
1995 Mitsubishi 3000GT VR4
1991 Honda's CRX HF
0bLiViOuS is offline   Reply With Quote
Old 09-16-2018, 10:45 PM   #4
KingKhan
Member
Drives: GTI
Thanks guys for the replies.
I'm not sure why Rock Auto listed the oem size as 0.032".
I'll have to measure the gap to confirm on the plugs.
Sent from my SM-N950U1 using Tapatalk
Old 09-20-2018, 03:11 PM   #5
seanmcd
Senior Member
The factory manual lists the gap at .7 to .8 mm for both spark plug part numbers.
seanmcd is offline   Reply With Quote
Old 09-20-2018, 06:34 PM   #6
SugarMouth
Senior Member
SugarMouth's Avatar
Quote:
Translation, .0275" to .0314".
__________________
Old 09-21-2018, 07:45 PM   #7
wordsthatiwrote
Senior Member
wordsthatiwrote's Avatar
Drives: 2016 VW Golf GTI SE
I recommend checking out this video: https://www.youtube.com/watch?v=iGiTXYWmSQs
Then make your adjustments as necessary?
__________________
AEM Intake | Forge BOV | Cobb Access Port w/ Cobb Stage 3 | NGK Iridium BKR7EIX Spark Plugs gapped to .025 | MA Performance Catless Downpipe | Unitronic Intercooler | Cobb cat back exhaust
wordsthatiwrote is offline   Reply With Quote
Old 09-21-2018, 08:10 PM   #8
SugarMouth
Senior Member
SugarMouth's Avatar
The guy is 100% stock.
__________________
Old 09-21-2018, 08:28 PM   #9
wordsthatiwrote
Senior Member
Quote:
I don't understand. Stock? :P
Sometimes reading > Me
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
