FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > GTI & Golf MK7 General Discussions
Reply
Thread Tools Display Modes
Old 09-15-2018, 05:18 PM   #1
gtifisherman
Junior Member
Drives: 2017 GTI S 6MT
Canít get strut back in 2x4 method, help!
Just like the title sayís... 2017 gti s 6 speed. Used the 2x4 method to pop out the strut and now it seems if I donít have enough clearance to pop it he strut back in. This is with a VWR spring in the strut too, should be shorter. The axle hits the sub frame when there is still about an inch need. Tried everything but canít make it work. Any ideas short of removing the axle?
gtifisherman is offline   Reply With Quote
Old 09-15-2018, 05:28 PM   #2
TheWedgie
Member
Drives: 2017 Volkswagen Golf GTI SE
Quote:
Are you raising the strut back up with the 2x4 method to get the clearance you need to realign? Then you just lower your jack to get it started back in the boot.
If that's not working for some reason... You might as well just remove the 6 (or maybe 8?) axle bolts... It's really not that bad removing/reinstalling those bolts (unless your car is high mileage).
TheWedgie is offline   Reply With Quote
Old 09-15-2018, 06:05 PM   #3
gtifisherman
Junior Member
I was trying to raise it back with the 2x4 but I can’t keep it in place. I think I’m going to drill a hole in the 2x4 and mount it to the strut. I just discovered that trick in another thread. Will report back.
Old 09-15-2018, 06:10 PM   #4
Shortybdub
Senior Member
Drives: My wife crazy
I was trying to raise it back with the 2x4 but I canít keep it in place. I think Iím going to drill a hole in the 2x4 and mount it to the strut. I just discovered that trick in another thread. Will report back.
Bingo.
Also, this is a good read:
https://www.golfmk7.com/forums/showthread.php?t=22788
__________________
2016 GTI ABCDSGLMNOPP, JB4, IE DP, Neuspeed FMIC, Racingline R600, TIP, TMD, Eibach Pro-Kit & RSB, Pretorias, Masterbadge.
Shortybdub is offline   Reply With Quote
Old 09-15-2018, 09:59 PM   #5
dwvw
Senior Member
Drives: 2015 GTI, 1987 BMW E30, 1965VW Beetle
Yup, bolt the 2x4 to the sway bar mount. Keeps everything in place.
__________________
2016 Golf R, IE intake/intercooler, AFR downpipe, Tomioka IHx475, AFR Eurodyne Maestro/TCU, TurboSmart EM, Nuespeed RSe10 19x19, MSS Kits, S2T paddle shifters, P3 Cars gauge
dwvw is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
