Old 08-20-2018, 07:04 PM   #885
GLoBaLReBeL
Drives: 2016 Golf GTI
The fan blades are far enough from that plastic support piece that even if there was momentary push from the piping, it wouldn't cause an issue. I had the same fitment problem, and while I was worried at first, I haven't seen any issues.
Daily Driver: 16' GTI
GLoBaLReBeL is offline   Reply With Quote
Old 08-21-2018, 02:39 AM   #886
arob157
Drives: 2017 VW GTI SE DSG
Decided to take a look at IATs today to make me smile. Used obdEleven for simplicity. Low and behold they were quite higher than they should have been. The morning before I took some logs and they were fine. Temps were 71F ambient both days. Intake temps were 100F+. They would drop in an aftermarket intercooler trend, but were just too high for something not to have been wrong. Boost and all looked good, timing wasn't too far off.
Checked all hoses and and everything looked great. Was gonna just leave it to heat soak, but something was fishy. Took the intake cowl off and was inspecting the seal etc. Went to reinstall and sure enough, I had not seated it into the grill all the way. Hopefully that helps. Didn't remember it installing that far. I had installed it into the first bolt slot that is actually for the tab to seat into.
Just a lesson from someone who missed that detail.
ED Stage 2 e50 ECU & Stage 1 DSG // Stock Intake Mods // Autotech Intake // Unitronic TIP // Magic IC // IE Downpipe // EuroCode RSB // Moog K750809 Endlinks
arob157 is offline   Reply With Quote
Old 08-21-2018, 02:46 AM   #887
arob157
I definitely saw that. Now I need to put something in between the coolant hose and the intake. That is super close to the intake now as well.
Old 08-21-2018, 08:48 AM   #888
mk7gti2.0
Drives: 2016 VW Golf R
Honestly temps will be 20 to 30 degrees over ambient with this intercooler if it's hot outside and your just cruising around especially with the AC on. But WOT will drop temps down very quickly sometimes only a degree or two higher than ambient.
mk7gti2.0 is offline   Reply With Quote
Old 08-21-2018, 05:23 PM   #889
arob157
I suppose that is one 'disadvantage' to a stock location IC. That being said, my IATs were drastically better this AM after correcting my install error. I was pulling in a ton of air from the engine bay. Gonna get one of the factory blocker plates for the intake as well.
Maybe some heat tape for the radiator hose under the intake. The intake is actually up against the radiator in one location (albeit extremely minor).
Old 08-27-2018, 04:40 PM   #890
aameghoo
Drives: 2015 Golf R
Thumbs up
Originally Posted by Renck View Post
Stop asking questions and buy it already............
Not an R (as you know), but I used the stock hoses. They were in really good shape and hence I was able to use them to keep the stock look at my car.
Ordered the Intercooler Thursday Aug 16 and received it exactly one week later Aug 23. With the help of Renck, we got the intercooler installed last Friday. Didn't have any issues at all really. To his suggestion we shaved BOTH posts, not just one, to match the factory intercooler in my 15' R and everything fit perfectly on the first try. No gaps after putting everything together.
With the AC off, I'm now only about 10 degrees above ambient after extended runs. We went on a 4 hour mountain drive this past weekend and heatsoak was nonexistent, power delivery was much more consistent compared to previous drives.
Here's a 360 timelapse of the install, remember you can pan around in the video, again shoutout to Renck, he was a ton of help with the install
360 Degree Timelapse video of install
https://youtu.be/OSNFrcuy7-4
aameghoo is offline   Reply With Quote
Old 08-27-2018, 08:28 PM   #891
mk7gti2.0
Good to hear it's doing better since you fixed the intake. But you are right the bigger intercooler takes more psi to push the air across the bigger core. But really heatsoak isn't really much a issue. Definitely well worth the 250 bux it cost.
Old 08-27-2018, 09:00 PM   #892
GTI7871
Drives: 2016 GTI
This is pretty much the same with any IC upgrade of this size. Iíve been running this IC in S Florida with 0 issues and loving it every day!
2016 GTI DSG w/ PP, COBB MAP Stage 1, RS7 Spark Plugs, Modified Intake box w/ K&N filter, Ebay/MAGIC IC.
GTI7871 is online now   Reply With Quote
Old 08-28-2018, 05:33 AM   #893
geokilla
Drives: 2018 Volkswagen GTI DSG with DAP
Probably going to pick up the intercooler tomorrow since eBay has 15% off and then eBates Canada has 15% cash back on top. Aside from the intercooler and the hoses, did anyone need to buy anything else? I recall reading something about plastic clips or something.
My GTI is stock right now but I plan on upgrading to Stage 1 in the future. Don't know how long these 15% deals will last but I figure nothing can beat 15% off plus an additional 15% cash back even if eBay keeps on having these 15% off promotions for the next year.
Stock 2018 Volkswagen GTI DSG with DAP
Dark Iron Blue
14,500km
geokilla is offline   Reply With Quote
Old 08-28-2018, 06:20 AM   #894
Clem604
Drives: 2018 GTI
You don't even need the extra hoses really, you can just reuse the stock ones. As for the clips, they help in the sense that you can just break the existing clips off the IC as a much easier way of getting them off.
MK7.5 GTI 6MT
JB1/Majesty IC/034 Upper+Lower Dogbone Mount/034 Eng+Trans Mounts/APR Pendulum Mount/034 Intake/APR TIP/Forge TMD/Remus Axleback/Neuspeed Short Shifter/42 DD Shifter Bushings/ECS Clutch Bleeder/ECS Clutch Line/WCT Pedal Spacer/DG Springs/EuroCode F/R Chassis Bars/H&R 24mm RSB/EBC Redstuff Pads/18x8 OZ Alleggerita/Riken Raptor 235/40/18
Clem604 is offline   Reply With Quote
Old 09-09-2018, 06:54 PM   #895
Stump909
Drives: 2016 Golf R DSG
I’ve noticed more brands are starting to pop-up, some with visual differences like uniformly shaped inlet/outlet (ie doesnt taper off to a smaller diameter) and inlet fins.
Stump909 is offline   Reply With Quote
Old 09-19-2018, 04:29 PM   #896
geokilla
I received my intercooler and didn't inspect it yet. However a friend was saying that his boss has a modified RX-8, and when you upgrade your intercooler you also need to upgrade the thermostats and sensors so the ECU knows the air from the intercooler is colder for the engine and what not. Is that required?
Dark Iron Blue
14,500km
Old 09-19-2018, 09:22 PM   #897
GTI7871
Drives: 2016 GTI
None of that is required for our cars.
Old 09-20-2018, 02:21 PM   #898
ITGUY
Drives: 2016 GTI
I'm going to say I've never heard of that... why would you change the thermostats and air temp sensors when that is what they do.. detect temperature?
Shorty's Short Shifter, Eurodyne -Maestro, Eurocode Catted Downpipe, Peloquin LSD for 02Q, SQS Racing bronze shift fork feet, SACHS Performance Clutch Kit OE 06K141015B, VooDoo Magic IC (Ebay intercooler), Eibach Front and Rear Sway Bars, iAbed RMS, 034Motorsports Engine Mount Set, Revo Engine mount, VW OEM 0A5141671F TOB, ECS SS Clutch line, Clutch Delay valve delete. Big hole in my pocket mod..
ITGUY is offline   Reply With Quote
Old 09-20-2018, 02:30 PM   #899
Oldschoolmk7
Oldschoolmk7's Avatar
Drives: Mk7 GTI
Make sure yall once the front bumper clip is off to pop out the air diverters on both sides of grill area. This helps bring in more air into sandwich condenser/ic/radiator area. My A/C blew ice cold. .
2016 GTI S 2 door, stage .5, gonzo
2018 Mustang GT, 10r80, pp, Unleashed tuning 93P, E85, Procharger D1-X and stuff... .
Old 09-29-2018, 12:16 PM   #900
afman916
Drives: 2016 GTI SE Pure White
So I’ll finally be installing this tomorrow and went and picked up hardware from Lowe’s last night. Unfortunately they only had M5x12 and M6x12 (and I’ll be using the 2” mending plate); will the couple extra mms of height pose a problem?
afman916 is offline   Reply With Quote
Old 09-30-2018, 04:15 PM   #901
wfujay
Drives: 2015 Subaru STi Limited
Former MKV GTI and current 2018 S3 owner here. This is probably one of the best and most informative threads I've read through...very entertaining read throughout. Props to Oldschoolmk7 for finding these IC's and inspiring the community to try them out and post relevant data.
I was super pumped reading through the thread and especially excited when I started seeing the data proving how well these performed, but not so excited when I saw the A3/S3 guys chiming in on how tight and less than perfect of a fit they are for our chassis. Now I wonder if all the big brands suffer this issue or if it's only a MAGIC/MAJESTY problem. Considering they look almost exactly like the Wagner IC, I'd suspect that one at least would present similar issues, so I'll probably still end up pulling the trigger on this one and hope for the best. The cost-performance ratio is just too good to pass up.
wfujay is offline   Reply With Quote
