FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Cosmetic Mods (interior & exterior modifications)
Reply
Thread Tools Display Modes
Old 04-25-2019, 06:45 AM   #647
replicate
Senior Member
Drives: Mk7 GTI Clubsport
I can confirm that the CS/CSS mounts do not prevent wheel hop. But they would have been necessary to handle the extra 50kw. Aftermarket mounts are still needed to eliminate wheel hop.
It could be that the CS/CSS mounts may be enough on a stock GTI to reduce it, especially with an insert.
I'm actually still deciding which engine mounts to go with. Most likely BFI stage 1 (they seem to get solid reviews) and then a Powerflex Hybrid dog-bone insert.
__________________
2018 NSW 6 Hour Regularity Relay Champion
2017, 2018 NSW CAMS Supersprint State Champion
Instgram au.gti.clubsport
Track Hack YouTube Channel
Track Hack Parts Store
replicate is offline   Reply With Quote
Old 06-15-2019, 05:13 PM   #648
cris.g
Junior Member
Drives: Golf 7 GTI PP
Hi guys, this is my first post here but I've been reding the forum for some time. Now I would need your advice with something, hopefully you can help.
So a while back I wanted to change my LCAs with the CSS ones, however the old part no. was no longer available anywhere, including VW dealers. After discussing with some shops and also VW dealers, the conclusion was that the part no. was changed from 5Q0407151K (CSS) to 81A407151C - but this one is listed for Audi A3 / 8V from 2017 and above. Does anyone know if these are really a replacement of the CSS ones and if they are a direct fit on the GTI MK7?
cris.g is offline   Reply With Quote
Old 06-16-2019, 04:02 AM   #649
replicate
Senior Member
A quick google shows this as a 17+ S3 control arm. It is highly possible that Audi started fitting this to the S3.
The only thing different as far as I know is the bushing. Part number is on the first page. You can just buy that for next to nothing and get it fitted. This is what I did. Installing Clubsport S parts on my MK7 GTI - Part 1 https://youtu.be/17OYY4dzMFY
__________________
Old 06-16-2019, 09:13 AM   #650
cris.g
Junior Member
I already have these A3 control arms, just want to be sure if they are a direct fit. The garage work here is very expensive for fitting them ~350-400 chf so I don't want to pay for it twice, in case I need to revert.
Left is original, right is Audi.
Old 06-16-2019, 06:40 PM   #651
777-300ER
Senior Member
777-300ER's Avatar
Drives: 2015 GTI SE PP
A3 should be the same as gti.
777-300ER is offline   Reply With Quote
Old 06-17-2019, 02:21 AM   #652
replicate
Senior Member
Yes they will be a direct fit. As you can se they are stamped slightly differently, but the only things you need to be concerned about are the holes for the headlight levellers, which look to be the only holes the same.
Personally I would opt for fresh bushes though if going to the trouble.
__________________
Old 06-17-2019, 08:18 PM   #653
cris.g
Junior Member
Thanks guys. For me there's no point to go for new bushes as I've already bought these A3 LCAs new. Actually I've already had them on the car, but the garage which did the work screwed up, on one side they used a wrong bolt (I don't even know where they got it from) and the car was pulling to one side when accelerating / braking, as the arm was not tightened properly. Not knowing what the issue was, I went to another garage and decided to go for originals. They found the issue with the bolt only after taking it out, and the one on the other side was already changed... These guys were not sure if the A3 arms played any role in it so thought it's better this way. But other then the issue with the pulling, I really loved how these felt on the car so if they're a direct fit I'll try to put them on the car again. Just wanted to get confirmation and make sure I don't pay for the work twice again, in case they didn't fit.
Old 06-18-2019, 01:16 AM   #654
replicate
Senior Member
That explains why they didn't look new. Yes they fit. Yes using the correct bolts and torquing to the correct value is critical. Which is 70nm +180deg.
__________________
Old 06-18-2019, 01:26 AM   #655
777-300ER
Senior Member
777-300ER's Avatar
Just also get an alignment afterwards. The pull could be caused by the control arms being longer and causing toe out.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
