FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > GTI & Golf MK7 General Discussions
Reply
Thread Tools Display Modes
Old 07-13-2018, 11:20 PM   #1
Micah247
Senior Member
Drives: MK7 Golf TDI
Advice for those with front BBK.
I never really put much thought into what would happen if I got a flat tire. Well today it happened. I pulled over, jacked up the car and removed the wheel. Just as I was about to put the donut on, I realized how will that be able to fit over my front BBK? Simple answer, it won't. I lucked out, I just happen to have a 30 mm H&R spacer. This gave me just the right amount of clearance. I don't believe a 20 mm spacer would have been enough.
__________________
Picture heavy TDI build thread
http://www.golfmk7.com/forums/showthread.php?t=39170
Micah247 is offline   Reply With Quote
Old 07-13-2018, 11:25 PM   #2
lumberjackzac
Senior Member
Drives: VW GTI '16
You put spare on rear and then rotate front flat with rear tire. Time consuming but that would be proper
__________________
'16 GTI S- DSG LP
Revo mounts Engine, Trans, Dogbone| DV+|All season DWS Conti|Allfit Lip|Escort Max360|Thinkware F770|
lumberjackzac is offline   Reply With Quote
Old 07-13-2018, 11:32 PM   #3
Mk7Will
Senior Member
Drives: MK7.5 Indium Grey 6MT Golf R
This
Mk7Will is offline   Reply With Quote
Old 07-13-2018, 11:40 PM   #4
BronxBomber
Senior Member
BronxBomber's Avatar
Drives: 2016 Mk7 GTi PP DSG
Bingo. Happened to me. Not ideal, but not the biggest deal in the world either. Assuming your not a stance head that's rockin' lower offset/wider rear wheels on a FWD/AWD car, which would probably cause an issue with them fitting on the front. Since you have a big brake kit, I'm assuming you're more about performance as opposed to stance fashion even though you are tuckin' tire lol.
__________________
Eurodyne DSG Tune, BC Racing coilovers, EBay DP, EBay Magic Intercooler, Magnaflow Catback, K&N Drop in, DBV2 TMD, DBV2 TIP, 034 Density Mounts, Power Flex Hybrid torque mount
BronxBomber is offline   Reply With Quote
Old 07-14-2018, 12:15 AM   #5
Micah247
Senior Member
Agreed. It was on my drivers side on a major interstate. The valve stem broke causing it to deflate rapidly. I have newly refinished BBS RS2 18" wheels. It's supposed to have a hidden valve in one of the belts, but the previous owner filled it in and drilled a valve on the inside of the wheel. Total bonehead move on his end, but I have to deal with it now. I was able to find a service station to install a new valve as I was limping 45 miles home.
__________________
Old 07-14-2018, 12:54 AM   #6
Golfs everyday
Senior Member
Drives: 17 Golf-R
Thanks for the heads up. Previous cars I've owned had factory BBK's and the spare cleared the calipers no issue.
While I would've figured it out on my own, it's good to have this knowledge beforehand.
__________________
2017 Golf-R DCC Nav 6MT
Golfs everyday is offline   Reply With Quote
Old 07-14-2018, 06:48 AM   #7
mattkosem
Member
Drives: 2018 Golf R
Spare goes on the back. I've had cars with factory BBK (MINIs) where the spare only fits on the back.
mattkosem is offline   Reply With Quote
Old 07-14-2018, 01:14 PM   #8
Golfs everyday
Senior Member
Drives: 17 Golf-R
The Cooper-S I had long time ago came with runflats.. not that I agree with runflats, the car came with no spare tire. But then my Golf-R has no spare either.
From experience though, most of the flats I've gotten were on the rear tires because of front tire kick up of nails and screws.
__________________
Old 08-21-2018, 04:29 PM   #9
tclap2136
Junior Member
Drives: 2015 GTI
Dumb question but what the hell is a BBK?
This belongs in that dumb question thread lol
tclap2136 is offline   Reply With Quote
Old 08-21-2018, 04:31 PM   #10
GolfWang
Senior Member
GolfWang's Avatar
Drives: '15 Night Blue DSG S
Big Brake Kit. Aftermarket brakes for track duty.
GolfWang is offline   Reply With Quote
Old 08-21-2018, 04:56 PM   #11
vw671
Senior Member
Drives: 2016 MK7 Golf-R
I got a BBK but Golf-R's don't come with spare tires so I don't have a problem
__________________
Instagram @vw671
vw671 is offline   Reply With Quote
Old 08-21-2018, 05:26 PM   #12
THEREALVRT
Senior Member
Drives: MK7 GTI
Quote:
and here i thought, this whole time, it was the german version of big black k.....
__________________
12.48@121 boss500. 94 octane. 27 psi. full weight. stk fueling system. stk catback. CTS catted DP,IC piping, IC and intake. 245/35/18 ps4s tires. 1/2 tank of gas. ED tcu and maestro.
THEREALVRT is offline   Reply With Quote
Old 08-21-2018, 05:34 PM   #13
nkresho
Senior Member
nkresho's Avatar
Drives: 2016 GTI DSG S & 2018 Atlas SE TECH 4mo
I'd put the spare on the back anyway, even if it did fit the front. Less weight on the tire, less load when accelerating or braking. Safer all around to have a less competent tire in the back than the front.
__________________
Moosetuned is38 & ED DSG - CTS DP - Rev9 Catback - VWR Springs - Koni Sports - Eibach RSB - Autotech Intake - No More Meth - Uni Intercooler - Underfloor Sub - Ed's HIDs - PP brakes w/ DS2500 pads
nkresho is offline   Reply With Quote
Old 08-21-2018, 06:24 PM   #14
gboticus
Member
Drives: 2015 GTI MK7 PP
I keep a spacer suitable for any axle with my spare tire and correct bolts to mount it.
Sent from my Pixel using Tapatalk
__________________
CSG 2015 MK7 GTI 6MT
HPA Hybrid IS38, Wagner IC, CTS engine/trans mounts, HPA dog bone insert, APR intake, Neuspeed discharge pipe, CTS TIP, HPA downpipe, Remus cat-back exhaust, Racingline catch-can, Neuspeed short shifter, Michelin PSS 235/40/R18, HPA BBK Front & Rears, KW V3 coilovers, 24mm H&R RSB, Vorshlag camber plates, Southbend Stage 2 Daily clutch.
gboticus is offline   Reply With Quote
Old 08-21-2018, 06:34 PM   #15
sprinks
Senior Member
Drives: GTI Mk7
Quote:
Winner winner chicken dinner. If you have a space saver spare, it's typically standard recommendation to rotate rear wheel to front (in case of a front wheel flat) and replace rear with space saver. This keeps the handling dynamics consistent in a vehicle where majority of your power, braking, and handling comes from the same set of wheels.
__________________
wheelwell & GTI mk7 journal
I cut vinyl stickers for cheap.
my mk7 stuff on ebay
sprinks is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
