FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > GTI & Golf MK7 General Discussions
Reply
Thread Tools Display Modes
Old 08-18-2019, 06:04 PM   #1
Avanti
Senior Member
Avanti's Avatar
Drives: Golf
Kessy Oil change reset....
without resetting the trip counter?
Avanti is offline   Reply With Quote
Old 08-18-2019, 07:49 PM   #2
Cptnjosh
Senior Member
Drives: 2017 GTI Sport DSG
Are you referring to the service interval warning that appears every 10,0000 miles? If so, how is that related to the Keyless Entry System?
Reset/clear service interval using using obd11 or vcds
Sorry, if i misunderstood the question
__________________
- JB4 Map 2, MSS Sport Kit w/ Swift springs, BMS Intercooler, ECS Billet Dogbone, Revo TIP and Panel Filter, MK7.5 Dynamic Tails
Cptnjosh is offline   Reply With Quote
Old 08-18-2019, 07:58 PM   #3
Avanti
Senior Member
Avanti's Avatar
Drives: Golf
The procedure as you maybe aware is to press an hold the trip counter button and then turn the ignition on and the display will switch to the reset menu, however on the kessy the ignition is semi on once the door is open and the trip counter resets.
I don't want the trip counter to reset only obtain the relevant menus.
Old 08-19-2019, 05:10 AM   #4
777-300ER
Senior Member
777-300ER's Avatar
Drives: 2015 GTI SE PP
It won't when you hold it and do it correctly the trip counter will not reset.
777-300ER is offline   Reply With Quote
Old 08-19-2019, 06:09 PM   #5
Senior Member
ReadTheBook's Avatar
Drives: '90 Cabby, CSG '17 GTI Sport
Quote:
Really? I've never had that happen and I do it correctly the first time every time. It ALWAYS resets to 0.0 as soon as I press it to hold it. Drives me nuts.
ReadTheBook is offline   Reply With Quote
Old 08-19-2019, 08:09 PM   #6
Exley
Junior Member
Drives: 2016 GTI PP
1. Press and hold trip button
2. Press start stop button without touching the brake
3. wait for the Reset Oil Life Message
4. Release and quickly press trip button.
5. Press start button without touching the brake
The trip briefly clears, but if you keep holding it will go back to your old trip mileage
Exley is offline   Reply With Quote
Old 08-20-2019, 02:59 AM   #7
Senior Member
Drives: 2018 Golf GTI SE
Quote:
The engine has to be off when you press the button. Then continue holding it and press the start button and a message will pop up to reset the oil change message. Follow the prompts. Your trip mileage won't get erased.
jimlloyd40 is offline   Reply With Quote
Old 08-20-2019, 11:19 AM   #8
Cptnjosh
Senior Member
Thumbs up
Where have I been? I was totally unaware of this procedure. This will come in handy next time around
__________________
Old 08-29-2019, 06:10 PM   #9
Avanti
Senior Member
Avanti's Avatar
Drives: Golf
Lol, that's what happened to me last time (it's only that I'm odd as in the trip counter and milometer are in sync)
Old 08-29-2019, 06:11 PM   #10
Avanti
Senior Member
Avanti's Avatar
Drives: Golf
Quote:
Just to update you all, I have managed the reset now without the trip counter resetting this time.
I sat in the car a few moments with the ignition off and the display was off, then ran the preferred procedure.
Thanks for all the responses.
Old 08-30-2019, 01:53 AM   #11
Senior Member
Good deal. I reset my trip mileage the first time also. I actually start getting the message pop up to change the oil 4000 miles ahead of time every time I start the car.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
