Old 12-14-2017, 05:12 PM   #1
Semi Cole
Drives: GTI
Any idea what could be wrong with my car?
I made a post with a video over on Reddit, here: https://www.reddit.com/r/GolfGTI/com...ning_any_idea/
Any ideas what the issue could be?
Semi Cole is offline   Reply With Quote
Old 12-14-2017, 05:15 PM   #2
armedferret
armedferret's Avatar
Drives: 17 SE DSG NBM
looks like it's the brakes.
just a thought, but if my car has 40k miles on it (it's difficult to see due to the quality of the video) and i'm getting warnings on the dash for "brakes" on a car that has wear sensors on the pads....maybe that's a good spot to start?
armedferret is offline   Reply With Quote
Old 12-14-2017, 05:21 PM   #3
BxGTI
BxGTI's Avatar
Drives: 2015 VW MK7 GTI, 2017 Audi A4 PP S Line2.0T
You need a new battery
2015 Tornado Red GTI MK7
BxGTI is offline   Reply With Quote
Old 12-14-2017, 05:40 PM   #4
Semi Cole
Drives: GTI
Nah it's not the brakes, just had it serviced at 40k and brakes still had plenty of life in them. Think that brake warning is just a symptom of whatever is wrong.
Old 12-14-2017, 05:41 PM   #5
Semi Cole
Drives: GTI
I tested the battery this morning and got right around 12v. All the lights and instruments are working fine as well, so I wasn't sure if it was the battery, but that was my hunch as well.
Old 12-14-2017, 05:50 PM   #6
miked617
Drives: 16 VW GTI Autobahn PP, DSG, JB4, K&N, MAP DP
Yup battery...12v even is a little low
2016 VW GTI Autobahn, DSG, PP, Unitronic Stage 2, Map Catted DP, Twintercooler, K&N Filter.
miked617 is offline   Reply With Quote
Old 12-14-2017, 06:07 PM   #7
Gibberoni
Drives: 2015 GTI SE (LP)
As others have said, its the battery. With everything in the new cars based on electronic sensors, when the battery starts to die, the cars go haywire.
As an extreme example, in my 2001 E46 BMW my battery started to die while I was driving down the road. I got a transmission error and the car refused to shift out of 2nd gear. My brake wear sensors blinked, and the parking brake light kept flashing. I had to drive 10 miles in 2nd gear... it was not pleasant.
Replaced the battery and all was good.
APR Stage II |AWE Track | Baun (GTIjake) DP | TTRS Clutch | BC Coilovers | BFI Shift Knob | ECS Bleeder Block | 034 Dogbone/Engine/Trans Mounts | More to come...
Gibberoni is offline   Reply With Quote
Old 12-14-2017, 06:10 PM   #8
BxGTI
BxGTI's Avatar
Yeah BMW's are notorious for this when the battery needs to be replaced
Old 12-14-2017, 06:14 PM   #9
Texas=heat=poor battery life.
As said, 12V is low. My Saab won't even bother trying to crank at 12V.
ED Moose ECU tune / ED DSG Stage 2 tune / Tomioka IHX475 Turbo / IE IC / MAP cat+res DP / Autotech HPFP / PR 450 LPFP / Uni TIP / EQT TMD and Pipes
Old 12-14-2017, 06:20 PM   #10
Semi Cole
Drives: GTI
Cool, thanks everyone. Looks like I'm gonna be going for a new battery once the wife gets home.
Old 12-14-2017, 06:40 PM   #11
Drives: 2016 Golf R
12 volts is VERY low.
Old 12-14-2017, 07:00 PM   #12
Semi Cole
Drives: GTI
From the few sources I checked online, 12.6 is a normal reading when the car is off, so I didn't think it was extremely low.
Old 12-14-2017, 07:09 PM   #13
https://forums.anandtech.com/threads...y-car.2349895/
Quick google search and good discussion explaining it.
Old 12-14-2017, 07:16 PM   #14
Drives: 2016 Golf R
2) A known-good battery is "dead" at 12.0 volts and fully charged at 12.6 volts.
Old 12-14-2017, 11:09 PM   #15
o_a_ravi
Drives: 2017 Golf TSI
Definitely the batteries. With Accessory ON, you read 12 which is enough to keep the dash lights and others happy.
But when you crank the engine, due to the starter load, the voltage gets pulled down to 8 volts or lower. Low enough to make the dashboard lights and controllers to go nuts., hence the infamous clicking sound and the christmas light show.
o_a_ravi is offline   Reply With Quote
Old 12-15-2017, 01:24 AM   #16
CG256
Drives: 2017 GTI SE
It's getting in the holiday mood by lighting up like a Christmas tree for you.
CG256 is offline   Reply With Quote
Old 12-15-2017, 01:36 AM   #17
o_a_ravi
I always plug in this on the lighter socket. Older Audiz used to have a battery gauge on the dashboard, used to be handy in these situations.
