Old 12-11-2017, 01:28 PM   #1
AdrenalineChick
AdrenalineChick's Avatar
Drives: 2017 Golf Alltrack SEL
VCDS - Passenger side mirror dip
I tried to enable the passenger side mirror dip when in reverse feature. I used the instructions shown below. Got through the first part fine. On the second part, I couldn’t find the step 4 “Access Control” (not the exact one that is in the instructions) in the drop down (or step 5 for that matter).
Has anyone done this and how? I must be missing something.
~Kimberly~
2017 Golf Alltrack SEL | DAP/Lighting | Platinum Gray Metallic
AdrenalineChick is offline   Reply With Quote
Old 12-11-2017, 03:49 PM   #2
Tricky Red
Drives: Golf GTE (MK7)
You just need to have the mirror positioner on the Right mirror and it will take care of itself. Should be in the handbook.
Any other position and it does not work
Tricky Red is offline   Reply With Quote
Old 12-11-2017, 04:50 PM   #3
nype
nype's Avatar
Drives: 2016 GTI Performance - DSG - Carbon Grey w/Leather
North American model. Not in the handbook because not an enabled option here.
nype is offline   Reply With Quote
Old 12-11-2017, 04:55 PM   #4
AdrenalineChick
Correct. I had tried it right after getting the car a couple weeks back, but it doesn't work. My 2002 Passat had this feature!
~Kimberly~
Old 12-11-2017, 05:16 PM   #5
Tricky Red
Strange decision by VW. Sorry not any help here then
Old 12-11-2017, 05:19 PM   #6
nype
nype's Avatar
Also, depending on the installed door module, the mirror may not return to the correct height.
Old 12-11-2017, 05:20 PM   #7
Squishy
Drives: 2015 GTI 6MT
I had this feature in my previous car and thought it was dumb, why would you even want it enabled? It does not help with backing up. You're just causing wear and tear on your mirror motor every time you shift in reverse. That motor isn't gonna last forever.
Squishy is offline   Reply With Quote
Old 12-11-2017, 05:26 PM   #8
SRGTD
Drives: Polo GTI
Really useful when parking parallel to the pavement (sidewalk), especially if you’ve got expensive alloys. You can see how far away from the raised kerbstone your wheels are.
2016 Polo GTI, Blue Silk. Gone but not forgotten; 2011 Mk6 Golf GTD, Carbon Steel Grey
SRGTD is offline   Reply With Quote
Old 12-11-2017, 05:28 PM   #9
Squishy
Can't you see the same view from the backup camera? I honestly don't know as I never have to parallel park.
Old 12-11-2017, 05:45 PM   #10
nype
nype's Avatar
Ya I was wondering, Barrie Ontario...aren’t the curbs usually snow covered? 🤪
Old 12-11-2017, 06:35 PM   #11
Twist
Twist's Avatar
Drives: 2018 Nightmare Golf
I used this for about three days before I turned it off. The problem is it doesn't return to your set position after it comes back up. So basically you have to reset your position everytime you use it. It comes back up but doesn't go to your saved setting, just the middle.
3 slow mk7s later..
Twist is offline   Reply With Quote
Old 12-11-2017, 06:37 PM   #12
Shane_Anigans
Shane_Anigans's Avatar
Drives: 2017 GTI Sport DSG
Mine doesn't, and it also angles itself outward.
2017 GTI Sport DSG - Tornado Red | Ask me about new car incentives
Shane_Anigans is offline   Reply With Quote
Old 12-11-2017, 06:57 PM   #13
AdrenalineChick
I only put it on the right side mirror when I was backing up next to a curb. I never left it on the right side.
Without the dip feature, I have to put the switch to the right and then adjust the mirror down to see the curb, then set it back after. It's a pain.
And I don't think using the backup camera really helps with you're trying to get right up tight to the curb (so you're not sticking out on the street).
~Kimberly~
Old 12-11-2017, 07:16 PM   #14
nype
nype's Avatar
Exactly my experience as well.
Once I installed power folding mirrors though, it now works properly. Always returns to preset height.
Old 12-11-2017, 08:18 PM   #15
NeedSleep
NeedSleep's Avatar
Because of the wide angle lense, it's hard to be as precise (read: close to the curb) as parking with the help of the mirror looking at the curb.
I grew up in San Francisco, where a couple of inches away from the curb can be the difference between a safe car and one that's side swiped by a taxi or a bus lol
Sent from my SM-G930T using Tapatalk
EQT ECU Tune (E40 Custom and 91 OTS maps) | EQT DSG Tune | BFI Stage 1 Engine Mount, Transmission Mount, Dogbone Insert | IE Intercooler | aFe dry filter
NeedSleep is offline   Reply With Quote
Old 12-11-2017, 09:22 PM   #16
taythecoug
Drives: 2017 VW GTI Autobahn 6MT
Same thing for me. On my old Audi it would go to the set position. With the GTI I have no idea what position it picks after the dip, but it was always needing adjusted.
taythecoug is offline   Reply With Quote
Old 12-11-2017, 10:20 PM   #17
ecsta
Drives: 2017 R
Its so easy to enable/disable (just if the mirror knob is set to R its enabled, otherwise disabled) so i just turn it on when im parking next to a curb. I think it's amazing for that, but otherwise useless, so its off 95% of the time. But when you're trying to get as close to the curb as possible its a great tool.
With power folding mirrors it returns correctly 100% of the time, i personally wouldn't make this tweak if i didn't have memory modules too much of a PITA to constantly adjust.
ecsta is offline   Reply With Quote
