FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > GTI & Golf MK7 General Discussions
Reply
Thread Tools Display Modes
Old 11-30-2017, 06:19 PM   #1
Mr. Bubbles
Member
Drives: 2016 Golf GTI se MK7 w/PP and LP
Transmission Rattle
So long story short, I have being hearing a rattle since 600 miles, when the clutch sperates the engine from the transmission it ceases to exist. Once the clutch is engaged and the input shaft starts spinning the noise starts again. I have been to the dealer 4 times(600 miles, 1500 miles, 3000 and 30000) for the same complaint they claim its gearlash and normal. My cars engine is stock. It is also worth noting the noise is getting worse especially during the summer. I am wondering if anyone has experianced a noise like this? Any advice is appreciated. My thoughs were input shaft bearing.
https://youtu.be/928PDR3M66Y
Mr. Bubbles is offline   Reply With Quote
Old 11-30-2017, 06:21 PM   #2
armedferret
Senior Member
armedferret's Avatar
Drives: 17 SE DSG NBM
Can't view youtube from where i am, but am assuming it's sort of rocks in a coffee can sound at low RPM?
if so, that could very likely be gear lash. My 350Z had it something terrible but it wasn't detrimental. just not something I was used to with that car.
if it's something different, i can't help ya. have you tried a different dealership just to get a different opinion in case they're stalling till warranty expires?
armedferret is offline   Reply With Quote
Old 11-30-2017, 06:27 PM   #3
Mr. Bubbles
Member
It is somewhat along those lines, but more of a knocking noise. My concern is that my buddies GTI ( Same Year and Model) Does not have the same noise in low RPMs, I planned on going Stage 1, but this transmission has me kinda concerned. Compared to my friends gti mine sounds like a diesel tractor. I have noticed more times that it was harder to get into 1st and 2nd, but that could be completely unrelated.
Old 11-30-2017, 06:32 PM   #4
russiankid
Senior Member
Drives: Das Auto
I would drain the fluid and see if it has any metal shavings. It doesn't sound terrible, but mine is quiet. I do have some clutch chatter that is only heard when its hot, on idle, and inside the car.
That noise can also be clutch related too.
russiankid is offline   Reply With Quote
Old 11-30-2017, 06:39 PM   #5
Mr. Bubbles
Member
The dealer is going to take a look on Tuesday and will most likely drain the fluid. I just find it hard to believe that there is such a stark difference in noise between my buddies and mine especially cus he abuses the snot outta it LMAO. Not to mention I never experienced a car that sounded like this in idle. Thanks for your input I appreciate it!
Old 12-02-2017, 06:09 PM   #6
plainsight
Member
Drives: 2016 VW GTI w/ LP
I have the same rattle in my 6 speed. Since I bought the car new. Dealer thinks it's normal but I think I have a defective DMF or something. I get a lot of gear whine too, do you get that? Worries me sometimes but car runs just like new 20k miles
plainsight is offline   Reply With Quote
Old 12-02-2017, 06:38 PM   #7
armedferret
Senior Member
Just watched the vid. If it's doing that in neutral it's either clutch chatter or something's wrong.
Old 12-02-2017, 07:46 PM   #8
Mr. Bubbles
Member
I get some, mainly in 1st and 2nd If I push the Clutch in the Rattle goes away and at the point of engagement it accentuates the noise then settles back into this pattern. The noise worries me like hell cus my friends GTI is very Quiet and I planned on going stage one once the warranty is up. The way the Transmission is sounding is making me think twice about that. VWoA said their Tech thinks its input shaft bearing given my description. I've wasted 1200 miles driving to my dealer and back as well as 7 hours each time as its a 2 hour drive each direction and they usually spend 3 hours with it.
Old 12-02-2017, 07:47 PM   #9
Mr. Bubbles
Member
Quote:
That is what I was thinking, but It sounds the worst by the drivers wheel which is closer to the transmission and the further under the car it gets fainter.
Old 12-02-2017, 08:17 PM   #10
tmw2442
Senior Member
Drives: Mk7 R
Sounds fairly normal to me...but it's always difficult to tell from a video recording.
tmw2442 is offline   Reply With Quote
Old 12-03-2017, 11:37 PM   #11
wakey1512
Junior Member
Drives: GTD MK7
Smile
Are you sure it's not clutch release bearing noise or (if fitted) dual mass flywheel? I understand your theory of gearbox input shaft but if the bearing was in a bad enough way to make this noise either from itself or gear noise you would expect fluid leak into the bell housing.
wakey1512 is offline   Reply With Quote
Old 12-04-2017, 03:33 PM   #12
Mr. Bubbles
Member
Quote:
That is a good point, but as far as clutch release bearing doesn't that typically squeals as you disengage the clutch? The rattle is occurring when in neutral with the clutch engaged(Pedal is Up). As the clutch disengages(Pedal Pressed) the noise quiets down, but as soon as the transmission shaft starts spinning(Clutch engages and pedal is released) again it's knocking.
Old 12-04-2017, 04:25 PM   #13
wakey1512
Junior Member
Drives: GTD MK7
Quote:
Usually when the release bearing is noisy it's worst engaged as the bearing is spinning on the pressure plate loosely. When disengaged the bearing is pressing the pressure plate and the compression on the bearing takes the free play out and can quieten the noise significantly.
Regardless of the cause removal of the gearbox will confirm whichever the cause is. It's just having the justification to pull it. Perhaps let it develop
Old 12-04-2017, 08:55 PM   #14
Mr. Bubbles
Member
That does make sense, I do know that my noise is worst in summer as the lubricants are thinner. I'm not sure there is anything I can do to make them have the justification and they keep maintaining that this is a normal noise. Im not sold on that as my friends isn't half as bad as mine. I have also noticed alot of times when I go to disengage from being in gear there is a rather large clash as the load is taken off, as well as periods of time where
it seems to require more effort to shift or doesn't shift as smooth, but that could be normal for all I know. I just know that the noise is getting more noticeable. I kinda wish it would just seize so they have to drop it out haha.
Old 12-16-2017, 12:03 AM   #15
Mr. Bubbles
Member
Update, when I took it in last week the tech heard the noise and attributed it to a bad input shaft bearing. So far a new transmission has been ordered and will arrive in 6 to 8 weeks! After a year of going nearly insane and 6 visits to the dealer my problem should be solved!
Old 12-16-2017, 01:19 AM   #16
armedferret
Senior Member
Glad to hear man.
LONG ago I had a 92 integra. Lost a bearing on the input shaft driving from the twin cities back to central iowa.
That was a really long tow. And a really bad day.
Old 12-16-2017, 01:22 AM   #17
Oldschoolmk7
Senior Member
Oldschoolmk7's Avatar
Drives: Mk7 GTI
Over 14k miles and have owned car since new and zero rattle. Glad dealer is sorting it out for you.
__________________
2016 GTI S 2 door, stage .5, gonzo
2018 Mustang GT, 10r80, pp, Unleashed tuning 93P, E85, Procharger D1-X and stuff... .
Oldschoolmk7 is offline   Reply With Quote
Reply
Tags
noise, transmission
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
